HP-D3057F3H low 5vsb
  • nubinator
    • Jan 2012
    • 37
    Hi i was given a PC which supposedly had bad mobo but turned out its the PSU. its HP-D3057F3H PSU and it wont turn on when connected to mobo but turns on when i short the green and black wire. then i saw the 5vsb is only 2v when connected to mobo and 5v when not connected. could this just be a bad cap in PSU? when i opened it up there was swollen cap its a 10v 2200uf Ltec but i dont know if that for the 5vsb
  • dmill89
    • Dec 2011
    • 2542
    Re: HP-D3057F3H low 5vsb
    I wouldn't usually expect a cap that big on the 5VSB but I suppose it is possible. A bad cap could definitely cause the rail to go low like that, I've seen it multiple times. There is the possibility that other caps are bad besides the one that is swollen, caps don't always show visible signs of failure. If you do repair it I would recommend replacing all the caps from questionable brands (in that PSU probably every cap or almost every cap, since HiPro tends to use lower end caps). That being said since it is a 300w HiPro and is standard ATX you may just want to replace the PSU unless you want a hobby project since it is only a mediocre brand and a suitable replacement can be had for less than $35.
    • retiredcaps
      • Apr 2010
      • 9271
      On an Antec SP450, there is a 2200uF 10V on the 5v standby so it is possible.
      Luckily the 5V standby rail didn't fail high otherwise it would smoked the motherboard.
      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
      Subscribe to support us. It only takes 1 minute:
      https://www.badcaps.net/settings/subscriptions
      • nubinator
        • Jan 2012
        • 37
        well got out esr meter i never use and it picked a couple of teapo caps 1000uf 6.3v and 1000uf 10v as bad also so will replace them see how it goes.
        • dmill89
          • Dec 2011
          • 2542
          1000uf caps are extremely common on the 5vsb rail so it is likely one of those is the culprit. As retiredcaps stated a 2200uf is used on the 5vsb in some designs, however such a large cap on a 2-3 amp rail is not very common. Although if the cap is visibly failed it still needs replaced regardless of what rail it is on since it will only lead to problems later.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5365
            • New Zealand
            • Electronics and computer repair
            It could still be something wrong with the motherboard, loading down the 5vSB so much that it ends up at 2v, unless you already tried a new PSU and found the board to work.
            -David VanHorn
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 692
              • samsara
              • non-causation of suffering
              My Hipro HP-D3057F3H only had 2.6V on the 5VSB
              The fault was due to 5ohm ESR on one of the non-bulged Teapo SC 1000uf output caps; so i guess that the Viper22A detects overcurrent, and goes into a low power mode
              BTW, this PSU has a tricky (for me), unusual, feedback circuitry on the 5VSB: The Viper22A is connected to the first optocoupler, of which the secondary side is earthed, and which is turned off or on by one of the TL431 shunt regulators (there's three on the secondary side of this PCB), which is connected to the adjacent optocoupler.
              Also, in terms of being able to remove the board from the case, this is a technician-friendly PSU
              • Realboy2314
                Read T470 bios chip while CMOS was connected, now laptop won't boot
                by Realboy2314
                Hello everybody,
                i want to start with saying that i'm pretty new to all of this (both the hardware and the software) and only did this with 2 desktops.
                My laptop is a T470 TYPE 20JN-S00U0L, i wanted to unlock the advanced menu just for the fun of it so i started by carefully disassembling the bottom cover, disconnecting the internal battery, locating the bios chip MX25L12873F on U49 and attaching the clip on it.
                i connected the green ch341 set at 3.3v to the pc and tried to read it using ASProgrammer.
                To be sure i read the chip 2-3 times and checked the bin files with ImHex...
                01-25-2026, 03:44 PM
              • reformatt
                Weird A2442 (820-02098) power on issue with battery connected
                by reformatt
                Machine came in as not powering on. Been to Apple who quoted a replacement board of course. So first thing was disconnect battery and plug in USB-C and it powers on fine. Plugged it all back in and boots to the OS just fine. It had a real old version of Monterey on it but looked pretty normal, so was scratching my head until I shut it down.
                So what I found is that when this unit shuts down, it refuses to power back on via power button or lid open. PPBUS_AON and PP3V3_AON all stable, but just won't power on. When you plug in USB-C or MAGSAFE, PPBUS_AON is stable however PP3V3_AON now...
                06-05-2026, 07:11 PM
              • Spillet45
                MacBook Pro Retina 15-inch (A1398) (820-00163A) Does not power on, thinks a battery is connected.
                by Spillet45
                Hello everyone! I'm trying to diagnose a fault. I don't have much experience, so I would appreciate any help.
                Symptoms:
                It stopped charging, drained the battery completely, and shut down. When powered from the adapter, it shows the battery symbol with a lightning bolt and then turns off. Without the adapter — completely dead. The charging indicator does not light up. Once I managed to start it using shift+opt+cmd+power for 5 seconds, then only power for 5 seconds, and then a short press on power. (I assume this was some kind of SMC bypass, found it somewhere on the internet)....
                05-29-2026, 01:39 AM
              • goop
                Which 820uF 6.3V caps for Asus P5G41T-M LX mobo?
                by goop
                What are the current favorite and available caps, maybe even polys, to replace 820uF 6.3V 8x11.5mm electrolytics?
                The Asus P5G41T-M LX motherboard is similar to the one in the photo.
                I've noticed 2 bulgy caps, one close above the north bridge, one below the south bridge.
                Like most of the other caps on the mobo they are:
                TK ATWY
                820uF 6.3V
                36 mOhm ESR
                1140 mA ripple
                Symptoms:
                The mobo's gone downhill fast. It got stuck or rebooted maybe a handful of times over a few weeks or months.
                Then one day multiple BSODs and...
                05-16-2026, 01:56 AM
              • kotel studios
                FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                by kotel studios
                Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                Any ideas where to go next?
                02-23-2025, 11:47 AM
