iMAC G5 Power Supply API4PC46-290 REV.A pin 8 no voltage
  • torgeson5kqs
    • Mar 2011
    • 116
    Re: iMAC G5 Power Supply API4PC46-290 REV.A pin 8 no voltage
    Ok Anyway so is this the PFC MOSFET that is not turned on or could be bad?
    • Toasty
      • Jul 2007
      • 4171
      No. PFC is only on when the supply is on, not in standby.
      There is no "PFC MOSFET" per se. Just the main switchers.
      You are showing output voltages in standby. You should not.
      veritas odium parit
      • Toasty
        • Jul 2007
        • 4171
        Final determination was a wrong type of transistor was used in Q1. The SMD codes can be deceiving at times and so was the case here. A w1P is different from a W1p .
        Replaced Q1 with the correct version and the supply returned to proper operation. OP reports that he replaced the Q1 in the others that had the same issue and they are all back to normal.
        -Case Closed-
        Toast
        veritas odium parit
        • torgeson5kqs
          • Mar 2011
          • 116
          Toasty,
          Thanks again for all of your help.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
