Antec SL350P - component forensics
  • SpecialK
    • Aug 2011
    • 11
    Hi, I'm trying to fix an Antec SL350P that suffered from a blown 5VSB capacitor. I've identified the broken components, but there are two that are burnt beyond recognition. The first one is R18; it's a 1 watt resistor that's in parallel with that capacitor. The other component is Q6, which is located close to the two optocouplers of the main circuit. Can anyone identify those two components?
    I've found the schematic with the DM311 mod, but based on pictures here on this forum, when installing this mod most of the original components (like the capacitor, diodes, transistors) are left in place. Shouldn't they be removed if you're going for the mod?
    Regards,
    Kelly
  • everell
    • Jan 2009
    • 1514
    Re: Antec SL350P - component forensics
    I have looked at a SL400 and could not locate either component you are asking about. Everything is so crowded on this power supply. Your power supply is most likely equipped with a power factor correction circuit. Mine does not have that circuit. So post us some pictures and we can better help you.
    The DM311 mod is (in my opinion) very straightforward. It is not necessary to remove ALL of the old components in the 5vsb circuit, just the ones that might affect the DM311 circuit. That doesn't mean that you can't remove them. I just don't like busy work, removing components when it is not necessary.
    If Q6 is the big transistor connected to the heat sink, it is not used when doing the DM311 mod, so you won't need to replace it. When you post a picture of the pc board, circle the damaged resistor you need information about.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • SpecialK
      • Aug 2011
      • 11
      Hi everell, thanks for your reply. Attached you'll find a picture of the supply (I stripped out most of the broken components plus the heatsink).
      I'm looking for the transistor on the left, and the resistor (that's already removed) next to the bulging capacitor on the right.
      Kelly
      • everell
        • Jan 2009
        • 1514
        R18 is 470 ohms. Q6 is UTC (brand) 2SA684.
        • everell
          • Jan 2009
          • 1514
          I added the DM311 mod to an Antec SL400 two years ago. Here are a couple of pictures and some drawings.
          The drawings show the original 5vsb circuit, a drawing showing which components needed to be removed (by using white out and removing them from the original drawing!), and a drawing showing how the final modified circuit should look.
          • SpecialK
            • Aug 2011
            • 11
            Thanks! This completes my shopping list. I must say the DM311 mod sounds appealing, because even if I just want to repair the supply, I'll have to replace quite a few components.
            This is what's broken:
            Q3 SSS4N60B
            Q5 2SC945p
            Q6 2SA684
            C8 47 uF, 35V
            ZD3 22V 500mA
            D? 1N4148
            R18 470R 1W
            R23 180R
            R22 1k
            So leaving the two-transistor design and just implementing the mod may not be a lot of extra work.
            I'll sleep on it
            • everell
              • Jan 2009
              • 1514
              For further reference, here are two pictures showing the board layout of the DM311 mod. The heat sink is a piece of tin cut out from a mixed nuts can. The mixed nuts were great. Isn't it nice when even the can is used instead of being total trash! Please note that all tin cans will NOT take solder, but the solder will bubble up and not stick. The ones to use will easily take solder, and you will see the solder flow.
              This board is attached to the heat sink on a Bestec power supply, but it is the same board layout I use on all power supplies I put this mod on. Just a matter of where and how it is attached.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                Altoids tins take solder, not very well but it sticks.
                • SpecialK
                  • Aug 2011
                  • 11
                  I think I have some leftovers from copper pipes laying around; that seems a lot easier
                  • sirpsychol
                    Antec Earthwatts EA-380 smd element type/value
                    by sirpsychol
                    While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                    09-03-2023, 07:58 PM
                  • ajdrenter
                    Picking caps for Antec SU-380
                    by ajdrenter
                    In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                    https://www.badcaps.net/forum/showthread.php?t=14159
                    It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                    05-13-2023, 10:40 AM
                  • CWEastwood
                    Antec Smart Power SL300S capacitor replacement.
                    by CWEastwood
                    I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                    The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                    I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                    Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                    03-25-2023, 12:18 PM
                  • s_henya
                    Antec VP-600P and NE550M dead
                    by s_henya
                    Got in these 2 nice PSUs, both died after power surge.
                    Both seems to be suffering from the same fault.
                    Blown main fuse
                    Shorted N mosfet 550v
                    VP-600P: 5R280CE short between GDS
                    NE550M: MDF18N50 short between GDS
                    In terns of board layout these seems pretty identical.
                    From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                    I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                    Is it worth to try and replace the mosfets? is there a chance that the...
                    12-03-2024, 10:00 PM
                  • GnatGoSplat
                    Antec BP500U APFC Coil
                    by GnatGoSplat
                    Antec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
                    Anyway, cracked it open this morning, expecting it to just be the APFC cap...
                    11-02-2021, 09:22 AM
