Power Supply cap suggestions?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Power Supply cap suggestions?
    I would use these as replacements paying attention to the voltage.
    [Because their ESR is right for a typical PSU and they are 10mm.]
    https://www.badcaps.net/store/produc...products_id=56
    The up to 3300uF won't hurt anything there and might even be a slight benefit.
    Mann-Made Global Warming.
    - Dr Seuss
    • slap_happy
      • Nov 2011
      • 46
      Originally posted by c_hegge
      Maybe he meant RLP series
      It seems like RSP, but I pulled one out, attached is a pic front/back.
      • mockingbird
        • Dec 2008
        • 5488
        Does not have to be hooked to anything to see secondary voltages if you jumper it "ON".
        Ah, so just the jumper trick, green wire to ground... Thanks.
        • Toasty
          • Jul 2007
          • 4171
          >>It seems like RSP, but I pulled one out, attached is a pic front/back.<<
          Probably a OEM "special run" for Cooler Master. Not in their advertised product line.
          I think PCBONEZ meant:
          https://www.badcaps.net/store/produc...products_id=57
          for the 10v ones.
          Can you fit 30mm height?
          Toss us some pics if you would, please. Buncha voyeurs here
          veritas odium parit
          • slap_happy
            • Nov 2011
            • 46
            Originally posted by PCBONEZ
            Pardon my VRM comment.
            Was late and I forgot this was a PSU.
            This PSU does have two VRM daughterboards that have poly caps already, so you're right anyway. But the OST are on the four 12v rails.
            Thanks for your recommendation. You're extremely helpful here.
            Does the stuff about 85C apply even to the two big ones? This PSU does have NCC for the primary 270uf/330uf, but they are 85C. Should I replace them as long as I have it all apart? What about the various small ones around 47uf. They are 105C but they are also OST?
            This was a pricey PSU , around 180US. I found a review which says that the oem is AcBel Polytech, but why would cooler master allow OST if they are so bad in their top-end product?
            • Toasty
              • Jul 2007
              • 4171
              #26
              AcBel uses OST in many of their supplies. Then again, I have AcBel's with not an OST in sight. LOL!
              NCC primaries are fine at 85°C. They're working, but not stressed, as the secondary filter caps are. Reliable brand/company for the most part.
              veritas odium parit
                by sam_sam_sam
                03-31-2024, 02:12 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
