Re: Can a PSU damage the motherboard capacitors?
I have the following caps on sli motherboard:
3x KZJ 1000uF 16v
5x Rubycon 3300uF 6.3v MBZ
29x KZG 1000uF 6.3v
16x E.CAP 100UF 10V SS
4x KZJ 6.3V 1800UF
Do think that those are not reliable?, or which once do you think should I replace?
I did replaced all 5 with new once. I got and replaced them yesterday, but a week ago I went to a pc shop asking for some capacitors ( i could not wait any longer for the ordered once). He said to pull out some from the old motherboard showing me a ga-k8n pro-sli he had in a box. I got the whole motherboard. Tested it and is working fine, only the sound not.
So, I have two motherboards, and I do not know which one to use, I might go for the sli one, though the GA-K8NF-9 (with new caps) was working fine too.Leave a comment:
You shouldn't really use 2nd hand\used capacitors. Best to get brand new ones. Being impatient with electronics is a bad idea.Leave a comment:
I have just replaced the capacitors with Sanyo WG 6.3V 3300UF. So strange, all the other capacitors are Rubycon, Nichicon and one Sanyo. I do not know why the bigger once were 5 of NCC KZG 6.3V 3300UF. Everything went smoothly.
By the way, I could not wait for the capps to arrive and i went to a pc repairing store if i can get the capps faster. For € 5 tried to pull out 5 capps, (Rubycon) from a motherboard, gigabyte ga-k8n pro-sli. I gave hip €5 more for the whole motherboard.
I tested, updated the bios through Live XP CD, ( copied from usb stick to floppy disk the latest bios), booted from floppy drive and followed the steps of updating the bios.
It is working just fine, only the on board audio chip no, I could not make it going. I think is faulty. I ordered a sound card, a basic one.
I do not know which one to use, the GA-K8NF-9 or ga-k8n pro-sli ( this one has all the small capps, NCC KZG and big once Rubycon.
I will keep in eye on PSU. I do not think is something wrong with it. I think that the capps failed because of heat. I will put two 120mm fans, front, side and 92 mm at the back for better air flow.Leave a comment:
[Like in backwards or got put on line voltage or similar.]
To go pop something has to be making pressure inside the can.
I suppose plastics could/would off-gas something when they melt but I don't know if it would be enough to pop the can.
'I think' it would have to be so hot inside the plastic wants to burn before it would actually explode.
A while back I posted a defective OSCON that exploded on me.
What came out was definitely smoke.
.Leave a comment:
I've seen that too. It was a foxconn board and a cap near the ATX connector (Rubycon IIRC) got Antec'd.Leave a comment:
On one motherboard I have seen, it had several bulging capacitors (of which some were connected directly to the ATX power supply rails). These capacitors took up the ripple current from a poor quality PSU, causing them to heat up and bulge.Leave a comment:
I think if a polymer was going to fail it'd probably go bang like a Sacon FZ... wouldn't it?Leave a comment:
Fascinating... Thanks for the thorough explanation.Leave a comment:
Visualize Ripple damage to the oxide layer as chunks of oxide being ejected into the electrolyte due to the current direction in the 1/2 cycle of the Ripple that is opposite to the DC Bias. [In other words an electron going the wrong way knocks it loose.]
In a liquid:
The oxide chunks can float around and are inclined migrate back to the hole [or some other nearby hole] due to the 'pull' of the DC bias -and- the fact the hole is a thin spot so more leakage current will 'want' to go through the hole.
[The healing is quite similar to what happens in electroplating.]
In the plastic:
The oxide chunks aren't likely to travel very far in the first place and most will move right back to where they came from, but a few will travel far enough to 'get stuck' in the plastic and will never travel back to a hole.
That amount of oxide material is just lost permanently.
In reality these 'chunks' are molecules, but 'chunks' is easier to visualize.
Anyway: If you exceed the Ripple rating but only for a short time.
A Lytic will probably repair itself completely.
A Polymer won't.
.Last edited by PCBONEZ; 09-02-2011, 09:39 AM.Leave a comment:
Lytics can also fail without forming a gas. Just depends on what is going on.
There is no liquid in polymers. - Little chance of gasses.
One of the bad things about them is they have a smaller ability to self-heal the oxide layer. [Relative to Lytics.]
To counter that it's much more difficult to damage the layer in the first place, hence the higher Ripple ratings.
- But, if you do manage to damage it, it isn't going to heal over time, it's permanent.
.Last edited by PCBONEZ; 09-02-2011, 09:16 AM.Leave a comment:
If I understad it correctly, if a PSU is not filtering out enough ripple because of lousy capacitors, this ripple now has to be filtered by the motherboard's capacitors...
Actually, I heard of someone replacing an all polymer Asus M3A78-EM... Point is, if these PSUs damage some of the polymer caps, go now and figure out which caps you have to replace without an ESR meter... Either the motherboard had other problems, or rather, like I suspect, polymer capacitors can fail without bloating...
How polymer capacitors can fail without external signs boggles me... It's hermetically sealed, so the only thing I can think of is the polymer drying out inside the can, but without enough pressure that would actually cause it to bulge.Leave a comment:
Yes, a PSU can cause caps to fail. No, I don't think that's what happened here.
KZG are known to fail. Chances are, it was a mix of heat and age that did these in.Leave a comment:
The CPU cooler cools the CPU not the Northbridge for the most part. Most of the Gigabyte boards I have seen run as high as 70C on the northbridge and Gigabyte states that under 80C is fine esp if its a passive cooled northbridge.
Anyway none of what you posted has anything to do with his VRM caps going bad other than maybe because the crap KZG caps failed because of the added heat in the case in which adding another case fan to remove heat from the case and keeping the caps cooler may help his northbridge temp is fine.Leave a comment:
What was the Northbridge temperature with the old cooler? 60C is way too hot for a socket 939 motherboard.
Did the old PSU fail? Are you overclocking?
Make sure your cooler is fastened properly. I assume you used paste on top of the CPU when you mounted the heatsink?Leave a comment:
It is possible for a bad PSU to kill a motherboard or it's caps. However, the KZG caps are notorious for going bad so it was likely just going to happen.Leave a comment:
Thanks for quick replay. I will wait to get the capacitors and change them.
The PSU is only two weeks old. I never heard anyone saying that Antec New 750 could go that bad. It runs fine and quiet so far.Leave a comment:
Yes a bad PSU can damage the caps on a motherboard. More than likely though those caps were going bad anyway, I would replace all the KZG caps before I used it anymore.Leave a comment:
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by stanwebberi've got a pretty rare motherboard that i'm evaluating for repair. it's a biostar m7mia-raid which is the only ddr socket a motherboard ever produced, consumer or industrial, with an isa slot. its 20 years old now and finally gave up the ghost last month. i was saving a dd image of the hdd to a portable usb drive when i found it unresponsive with a black screen and a solid lit hdd led. after forcing it to power down it never posted again. the psu/cpu/case fans will spin and the onboard motherboard power led will light up, but no beeps or error codes even with the cmos reset and ram plus all expansion...
Channel: General Capacitor Questions & Issues
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by varkatopeHey there, retro fans.
I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...1 Photo -
by zklgfsHi,
I have a Dell Latitude 5590 with motherboard LA-F411P Rev 1.0 that has liquid damage and doesn't turn on anymore when only the charger is plugged in. However, it does turn on when powering it from a battery. I couldn't find schematics for this exact board, but LA-F401P seems to be similar (that post says LA-F411P, but the attached schematics are actually for LA-F401P): https://www.badcaps.net/forum/troubl...oardview-neede... - Loading...
