E13009F and J13009-2
  • squeeish
    • 15
    Are the two the same?
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: E13009F and J13009-2
    No.
    The new one is not insulated.
    There are two types one insulated and one that is not.
    the one with the metal tab requires what is shown in the pic.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • squeeish
      • 15
      Ah thanks! Looks like I wasted $3 then.
      But they're essentially the same component?
      • Agent24
        I see dead caps
        • Oct 2007
        • 5020
        • New Zealand
        You didn't waste $3, just get some insulating washers and you should be fine.
        -David VanHorn
        • squeeish
          • 15
          It isn't of use anymore, I just blew the fuse on the power supply and tripped the circuit breaker in my home when the power supply I was attempting to repair fell and landed on metal... and as luck would have it, the other transistor got shorted.
          I suppose that transistor is unusable now.
          • TechMark1
            Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
            by TechMark1
            I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
            Yesterday, 03:36 PM
          • MaxonDomkrat
            Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
            by MaxonDomkrat
            Hi everyone.
            I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
            07-30-2025, 01:27 PM
          • cannifixit
            HP Elitebook 6050A3299901-MB-AX1 mystery model, need help identifying it
            by cannifixit
            I recently bought a faulty Elitebook from ebay, and that was exactly how it was listed just "HP Elitebook", no details.
            It has two issues, the first being in manufacturing mode for the bios, which from my understanding essentially means a bios has been flashed that does not have any of the laptops details, model, serial number etc.
            The second issue is it does not charge which I'm sure I'll be ok with once i get into it.
            The bios issue is a problem though as the laptop is missing all of the details on the bottom case, it's completely blank, it's not like they...
            06-24-2025, 03:50 AM
          • markk8799
            Confirmation on replacement caps
            by markk8799
            I'm replacing a swollen cap in the PSU of a Samsung UN40EH8000F TV. The cap is a Samyoung 10 V, 1200uF, 105 degree C, NXE series. From what I can gather, the NXE series is essentially those specs, with 20% tolerance, ultra-low ESR, low impedance, and long life (3-4,000 hours). On Dikigey, I was looking at the Panasonic EEU-FC1A122 or EEU-FK1A122L. The only thing I can discern between the two is a difference in impedance (44 vs 52 mOhms). Any suggestions are greatly appreciated. Thanks!
            05-23-2025, 08:25 PM
          • AJ847.63e
            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
            by AJ847.63e
            Hi Folks,
            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
            05-06-2025, 10:37 PM
