Check if 450v 560uF cap is blown using multimeter?
  • Fuze
    • Jul 2011
    My PSU kicked the bucket this morning, I could smell it when I opened it up, but there is no clue as to which components were responsible. Nothing is bulged of charred.
    Going by smell, I suspect it may have been the giant 450v 560uF capacitor (nippon), even though it is cosmetically perfect, no bulging, leaking, or discoloration.
    I hooked my cheap multimeter up to the contacts (short-circuit test) and nothing (no beep). I also tested resistance (again, testing for any sort of connection) and again, no reading.
    I hear large caps can't be tested like that bc the cheaper multimeters dont provide enough current to register, but I still suspect that I should be able to get some sort of a reading.
    Any experts here have any advice?
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Check if 450v 560uF cap is blown using multimeter?
    What type of smell was it? If it is a sharp smell it's probably a semiconductor, and those can let out smoke without being obviously damaged (only a small crack in the case).
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      http://www.youtube.com/watch?v=WjAPoN8qs0Q
      Mann-Made Global Warming.
      - Dr Seuss
      • Krankshaft
        • Jan 2007
        • 2328
        The resistance should start low and slowly climb till the meter reads OL. This test proves nothing other than the cap isn't shorted or open.
        Highly unlikely the line cap went it's probably a semiconductor.
        Is the main fuse blown?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          W/DMM it should flash numbers [charging] then go to OL [charged] and stay.
          Then reverse the leads. Should see the same on the meter as it charges the other way.
          [On analog meters you can watch the needle move. W/DMM it's always changing until OL and it's too fast for a number to lock-in and display.]
          For big-ass caps use a higher resistance scale.
          Not looking for a 'number', just a characteristic response.
          - Dr Seuss
          • dj8452000
            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
            by dj8452000
            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
            02-18-2025, 08:28 AM
          • drscoot
            HP X360 convertible battery blown fuse error, not charging
            by drscoot
            HP Modelnumber: 14-dh0061nb​
            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
            All these 3 batteries are charging...
            12-15-2023, 05:54 AM
          • cmlewis89
            LG 47LB5DF blown power supply board
            by cmlewis89
            Hi folks,
            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
            09-03-2024, 07:50 PM
          • swerg
            Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
            by swerg
            Hey everyone,
            I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
            I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
            I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
            06-06-2024, 03:39 PM
          • MrzPdlch
            Blown fuses on Gigabyte GTX 980TI 6GB
            by MrzPdlch
            Hey everyone,
            I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
            Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
            Find some pictures of the actual GPU together with a picture of how it should look like.
            I also wonder whther it might be a problem that there...
            03-10-2024, 04:14 PM
