Rebuilding a Panasonic ETX2MM702MF power supply
  • waitery
    • Feb 2011
    • 69
    I wanted to check to see if any of you had ever repaired/rebuilt a ETX2MM702MF power supply for a Panasonic Plasma television. Can you tell me if there is any standard part/parts to look for that represent a common failure with these boards? Fuses are all good and I have the ability, but have not started to test caps for ESR, as well as the diodes and fets with my Fluke, but wanted to see if there was a standard proceedure that a member might have before I forge ahead. Can you let me know?
  • creativeguitar
    • Jun 2011
    Re: Rebuilding a Panasonic ETX2MM702MF power supply
    same here..
    any suggestions?
    did you get to fix it ?
    • rustfarmer
      • Sep 2011
      • 8
      Sane here, but I am less knowledgeable and see no obviously burnt or blown parts. All caps look ok.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
        After all of...
        07-13-2024, 08:14 PM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
