SMPS high output voltage after recap
  • baritonomarchetto
    • May 2011
    • 8
    after recapping an old switch (+5V, +12V, -5V), the 5V line output minimum level (with load) is 4.9 V, which is higher than it was in origin. If i turn clockwise the voltage regulator pot, it even go in protection (tic-tic-tic) at middle position... what could it be?
    It's like the minimum 5V line voltage rise of about 0,5-1V with respect to the normal operation condition...
    Consider that i replaced all the caps with the exeption of the 2 big line filter caps AND that i used general pourpouses JH and Samwha caps (better choices where not at disposal at the local dealer )... could the high ESR being affecting the output thus causing the problem?
    thanks
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: SMPS high output voltage after recap
    Um, a 5v line is supposed to be 5v. That's why it's called a 5v line, duh. 4.9v is already "low". If it were lower before, it means the old caps sucked even harder than what you have put in now. Btw, ATX tolerances are 4.85 - 5.25v for the 5v rail. Which is +/-5%. Same goes for 3.3 and 12v.
    General purpose caps suck for this application. They're only gonna be good for a few months or so. The ESR could well be affecting the output, but you aren't going to see it if you don't have a scope.
    A working TV? How boring!
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      If this unit dosen't have a 3.3v line, it sounds like an AT unit, in which the tolerances were actually wider at +/- 10% for the 5v and 12v.
      • Pyr0Beast
        • Feb 2009
        • 406
        You mean 'abnormal' right ?
        Voltages usually are higher when capacitors are ok.
        • baritonomarchetto
          • May 2011
          • 8
          No, this is not correct: the pot allows you the control of the 5V line voltage from lower values to higher (this is because some PCB works at 4.80, another at 5.20 and so on) with respect to the "mean" 5V that should be obtainet at the half position.
          I don't think the prob lies in using new caps... at least if the project was a good one.
          Is it possible that higher ESR caps affect the circuit thus giving wrong output voltages?
          • brethin
            • Dec 2008
            • 1907
            I am assuming you are referring to a ATX PSU, if not then you need to state what PSU it is and what its for. For a ATX PSU the trim pot is there so you can adjust the output to 5v and stay in tolerance of 5v +/-5% ATX spec. It is not there for you to adjust down to 4.8 or up to 5.2. Half position on the pot means nothing and does not mean it will be 5v at half position.
            • baritonomarchetto
              • May 2011
              • 8
              thanks for your answers guys.
              The switch is not a PC switching but one used on amusement cabinets. It's not an ATX since is from 1989.
              Almost all the other similar switch i have give 5V at medium position (or close to it), and this one gave too before the recap.
              I can assure you that some PCB needs 4,8V to work correctly, others 5,2, others PCB values between those.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Then there's something else wrong with the boards themselves. Arcade cabinets are still computers, just that they were programmed for a single purpose - running a game. Here is a table that shows the voltage ranges for each type of logic, to clear your doubts.
                5v logic won't give a rat's ass whether you feed it 4.8, 5.0 or 5.2 volts. In fact it works just fine down to 4.0 volts, tested by me on a Z80 system. Some of the peripherals might start acting up but the main CPU is still alive and well at 4v. On the other hand if there are bad caps on the boards themselves, transitions from a low to a high level will make a big downward spike in their power supply, which may bring the signal below the threshold of 2.5v. However that's another problem entirely. Certainly, a voltage change from 4.8 to 4.9 volts... um, i hardly see how that would change anything in any kind of digital circuit.
                • baritonomarchetto
                  • May 2011
                  • 8
                  Yes and no
                  Generally what you stated is true, but especially very old boards had some voltage that need special tuning... maybe because of bad engineering
                  Anyhow, what can cause an abnormal high voltage on the 5V line on your experience?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Maybe they have some onboard regulators that went bad if they need tweaking to that level. Other than the analog circuits (namely CRT and audio) nothing should be critical about power supplies. Doubt there's any bad engineering in arcade cabinets - otherwise they would've gone out of service much sooner.
                    Higher than normal voltage can be produced by a feedback loop disturbance. The ESR of general purpose caps is significantly higher that what was on there originally - depending on the compensation scheme, this may cause the supply to oscillate and no longer achieve correct regulation. I strongly suggest you hunt for better caps.
                    • baritonomarchetto
                      • May 2011
                      • 8
                      Thank you very much
                      Arcade machines sometimes where really badly enginneared: one of the most citet case is Namco Pole Position: even if there are tons of those PCBs it's really hard to find a working PCB nowadays
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Eh, maybe they were simply played a lot.
                        • baritonomarchetto
                          • May 2011
                          • 8
                          hehe, not more than a joust or other williams boards... still working most of the times
                          • Scenic
                            o.O
                            • Sep 2007
                            • 2642
                            if you're working on arcade machines you might want to send maxxarcade (forum nickname) a message. he fixes those as his job IIRC.
                            • FrancescoV
                              Onkyo HT-R390 no sound output, video output ok
                              by FrancescoV
                              Good morning everyone,
                              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                              The firmware reported is the following:
                              M:1.00/11107BLP
                              D:?.??/????????
                              O:1.00/11107AL
                              The DSP firmware given the question marks seems corrupt.
                              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                              05-11-2025, 02:59 AM
                              Texas Instruments TPS51427ARHBT TPS51427ARHBR Dual D-CAP Synchronous Step-Down Controller for Laptop Computers
                              The TPS51427A TPS51427ARHBT TPS51427ARHBR are dual synchronous step-down controllers designed for laptop and mobile communications applications. This device is part of a low-cost suite of notebook power bus regulators that enables system designs with low external component counts.
                              The TPS51427A includes two pulse-width-modulation (PWM) controllers, SMPS1 and SMPS2. The output of SMPS1 can be adjusted from 0.7V to 5.9V, while the output of SMPS2 can be adjusted from 0.5V to 2.5V. This device also features a low-dropout (LDO) regulator that provides a 5-V/3.3-V output, or adjustable...
                              10-23-2024, 02:37 AM
                            • madan1
                              Troubleshooting half-bridge smps
                              by madan1
                              Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
                              The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
                              Both mosfets were tested outside circuit with a component tester and seem to be fine.
                              With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
                              So I guess the mosfet driver is faulty?
                              01-23-2025, 06:05 AM
                            • rstrube
                              ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                              by rstrube
                              Hi Everyone,
                              I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                              Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
                              11-23-2025, 12:19 PM
                            • feliks912
                              ThinkPad T490 20N2000CSC NM-B901 no signs of life - short on 5V SMPS, ThinkEngine-3 hot - *speculations*
                              by feliks912
                              Attached schematic 🙂.
                              Laptop gives no signs of life. No fan and no CPU heat.
                              Think Engine BD4179MWV is hot on plugging in *AND* pressing the power button.
                              Discovered short to ground on VCC5M power delivery IC NB690GRP (5 volt line, not the high current VCC5M_PD) which is one of the ways that chip is powered. I'm puzzled.
                              Nothing else is warm on the board. CPU resistances are OK, 9V VSYS line is present from the BMIC. All misc and cables are disconnected.
                              What do you guys think happened? I've got two theories:
                              If the...
                              I think ThinkEngine shorted first
                              50.00%
                              1
                              I think 5V SMIC shorted first
                              0%
                              0
                              I think something else happened
                              50.00%
                              1
                              05-07-2024, 04:44 PM
