SMPS Inductor 101
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    SMPS Inductor 101
    This paper will tell you all you need to know about inductors. All the math is there so i won't insist on it. However, what it does not tell you is how to actually measure them. Inductance and saturation flux density are the two important parameters.
    For the first, the simplest method is a multimeter with inductance measurements. I have recently bought one too. A lot of people will tell you that inductance measurements with a multimeter are pretty much worthless in SMPS applications because the inductors operate with a degree of DC bias that the multimeter cannot apply. What they did not tell you is that there is a really simple circuit you can use with your multimeter, that applies bias to your inductor so you can measure its inductance in real-world conditions! And you can make it out of junk parts. If you have some dead PSUs lying around then you have the parts needed.
    To measure maximum flux density (applicable mostly for ferrite, as iron cores have "soft saturation" and the limiting factor is core heating, not the inductance drop that occurs in saturation), you will need an oscilloscope. However, you should already have one if you're any serious about SMPS work. The beauty of it is that any old analog scope will do, while most circuits on the 'net say you need some math functions, or a scope with 2 channels - this couldn't be a bigger lie.
    It goes like this - apply pulsed voltage of known peak voltage and period (this is what your scope will help you determine), to a number of turns on the inductor, via a 1 ohm resistor (or something close). If the resistor gets hot, then your core is saturating. Increase the number of turns till the resistor remains cool. The pulsed voltage source can simply be the secondary of a computer PSU transformer, just take 2 wires and solder them to the 12v winding of the transformer and there you have it. Then apply Faraday's Law and you get operating flux density. Saves a lot of time rewinding transformers and replacing blown switching transistors that would otherwise result from a saturating core. And yes i have a calculator for that... but you'll have to wait until tomorrow.
    The circuits are soon to follow.
    A working TV? How boring!
  • Bartoloni
    Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
    by Bartoloni
    Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
    everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
    there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
    replaced the capacitor (330) and the inductor (R15) without any change
    any idea? very thank you!
    input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
    12-09-2024, 12:42 PM
  • badcap111
    How to read inductor specs?
    by badcap111
    I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
    INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
    I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
    09-12-2023, 01:25 PM
  • dkneyle
    Onkyo DX-V500 Laser Disc Player - weird SMPS fault
    by dkneyle
    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
    02-01-2022, 02:08 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • silver60618
    Blown Inductor on WD My Passport
    by silver60618
    Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
    Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
    Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
    Lastly am I correct in thinking there is no polarity on the smd component?
    Thanks!...
    04-05-2024, 09:54 AM
