OK I would like to find out if it is possible to replace one X-former as drop-in for another in switching power supply. I wan't to take a BFG 800 watt #E231049 VIKING B-2 (TOP-T614) X-Former and drop it in a CoolMax AP-550 (V-550) #EI-33B X-Former . EI-33B has bad secondary. Thanks for any Help in Advance Scott.
HI! My first post on the forum "bear" with me please and Thank's.
Re: HI! My first post on the forum "bear" with me please and Thank's.
Highly unlikely that these two are compatible. The coolmax V-550 is not a very high quality unit. The newer LongYi built units have ERL-35 size transformers, so this is a older Sunyo built unit. Better off fixing or using the BFG, which is a Topower built unit. They are generally pretty good after a recap.
Post some pics of both supplies. The BFG is likely to be using two transistor forward topology which is completely incompatible with the half bridge the coolmax uses.
EI-33 and "550W" do not go in the same sentence. It'll do 400 in a good day, but that's with a configuration that is never ever used in a cheap power supply. Most of the times they max out at 250.
But what do you mean about "bad secondary" ? If it reads shorted on your multimeter... that's what it should do. You can find EI-33 by the loads in most noname junkers, all are compatible, but the windings are of varying degree of quality.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I had 170 volts on primary of the cool max and nothing on output. I do have 5 volts on other rail no 12 v .Replaced caps some resisters and diodes on secondary.This includes the two stps20l45ct and sb1645ct. I thought maybe the bfg x-former could be converted or something. I guess I can wait to get another x-former down the line no rush, have other projects in the works. Thank's Scott. I'll Be Back.Comment
by notallbadHaving a quick look at this found a 25uf cap with no cap reading and xformer with open high side winding, theres an obvious brown out spot on the windings and has no continuity.
Should be ok getting a suitable replacement cap but seem to be having difficulty sourcing a xformer.
Also need to identify the component in the cap wiring connector, see last photo, which is connected between the 2 cap lugs.
From what I can make out its 240v pri, 0 - 9 - 0 - 24v sec dual output chassis mount transformer. Only markings on it is:
P-045 PUTRANS.
Any... -
by bobocheOk i'm fighting with this board and I don't want to give up because I know its something “simple” and that i'm blinded right now...
- all 3 mosfets were replaced, went from dead to powering up but mosfet heating up quickly up to burning out.
- removed battery, was dead, and unless I am mistaken, no battery attached shouldnt kill a mosfet on the mb.
- no capacitor shorts detected, would have been too easy.
Now the fun part
- if i apply voltage where the battery was, I won't turn on unless I plug the dc power. If I do... -
by kekelenHi everyone,
I’m a total beginner at electronics repair and have very limited knowledge about components, so please bear with me.
Problem:
The display on my HomeWizard Energy unit started flickering for a few minutes and then went completely dark. The backlight no longer works, but I can still faintly see the text on the screen under good lighting.
I tested the display itself on a drive control board (used for PC/Raspberry Pi), and the screen works fine — so the issue seems to be on the main board.
What I’ve tried so far:- Checked for
by asussucksHi there,
this is my first post so bear with me
my device is no longer in warranty. I am comfortable with doing minimal operations on the device. it has no data I formatted it thinking it's a software bug at first, but no it's something else.
What I tried: running it with disabled dGPU, running it with an external screen, resetting everything, using Linux on it instead of windows, reinstalling BIOS, using a different SSD, running it without internet, keeping it plugged to a wall, using a desktop cooler on the CPU, praying to god, contacting the CEO'S office...08-31-2025, 09:16 AM -
by Pfloyd36069Good afternoon everyone,
This is my first real post here. I am very new to a lot of this, so bear with me. I recently acquired a Nikon Z8 that had been dropped and will not power up. After removing the back of the camera, I found a large FPC cable that was half out of the connector. Great, I though I'd found the problem and reseated the cable and tested. Still no power. I started digging further and found an inductor that had overheated, bulged, and left a residue on the heatsink. I removed the inductor and retested, thinking maybe I would have some functionality, but still nothing....07-07-2025, 11:56 AM - Loading...
