A properly made power brick!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I found a good deal on a used pro DJ mixer (but more on that later on). It needs a bit of love (new faders, and the chrome on the faceplate is badly worn, i'll see what i can do about that), but it is technically OK for the most part.
    The mixer called for a 15v DC supply and it has a 7812 onboard. (yup, no split supplies, the whole thing is AC coupled, fortunately they used high quality ELNA caps). The supply it came with is a 12v, 1A switcher so it's naturally not enough. After the 7812 i get roughly 10.8v.
    The mixer works fine with it but i noticed a 15kHz whine that gets annoying when the volume is cranked. I disconnected all inputs from the mixer and the whine was still there, so i've narrowed it down to the power supply. I cracked it apart to have a look, and was surprised pleasantly by what i saw. Take a look at the attachments. The caps are Teapo and Su'scon, but all are good, there's a full transient filter on the input and a pi filter on the output, and a BIG varistor wired straight to the mains plug. So there's nothing wrong with it.
    It's an universal input supply (100-240v) and my mains is 230v, so a feedback loop adjustment should be all that's needed to bring it up to 15 volts. I'm hoping that bringing the 7812 back in regulation will give enough ripple rejection to get rid of the whine. Otherwise, it's probably calling for a linear... 15v at 500mA isn't a whole lot, and i have a suitable transformer lying around, but i'd have to ghetto a case for it, while the switcher looks nice so i'd rather make it work if possible.
    A working TV? How boring!
  • kikkoman
    • Jul 2007
    • 691
    Re: A properly made power brick!
    why do it the hard way?
    out with the 7812!
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      If anything awry happens, the 7812 fails short and protects the rest. If i remove the 7812 and something awry happens... i blow all the opamps.
      Anyway. Upped the voltage. No change (except blowing up the protection zener of the switcher). Exchanged with a (wimpy transformer) linear. A healthy dose of mains hum... and the whine is still there. It's not coming from the power supply but from the mixer board itself.
      There are some mods on the LED level meter, traces cut, a resistor and some bypass caps installed... the whine could be coming from there. The meter is driven by a BA6822s IC, i'll take a look at it now. Edit: Yup, the BA6822 uses an oscillator and has a switcher internally. The recommended oscillating frequency is 4kHz... eek. Yup, i think i found my problem.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        My bad, the mods were on the FX input section (which i don't need anyway). And i was barking at the wrong tree... the whine is coming from my soundcard.
        • Wizard
          • Mar 2008
          • 2296
          This SMPS wall wart is horrible especially for audio stuff. No smart IC and under volted. In a pro DJ Mixer. Tsk tsk. Clean power is critical.
          The mixer you will find the oscillation in one of circuit leaking out somewhere, find it with scope! Using a linear power supply and get hum means filtering circuit on the DJ boards are poor, improve them.
          Cheers, Wizard
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            No longer undervolted. And it doesn't have to be smart - it has to be clean.
            Or it means the transformer i had on hand was too small to handle the load (it was a 200mA trafo), and all the ripple got thru everything because the voltage dropped and the 7812 went out of regulation. The filtering is adequate in the mixer. With the switcher the only hum is picked up via the cables and it's a minute amount, and the whine only starts when i connect my soundcard, and it is very faint. It is never audible under normal conditions.
            Connecting the rec out to the line input of my soundcard gives the following levels on the spectrum analyzer of Sound Forge: 50Hz at -102dB, 150Hz at -101dB, 15.631Hz at -96dB. Overall noise floor is -71dB peak, -85dB RMS. With a mike connected and the mike gain maxed noise floor is -62dB peak, -75dB RMS and for the most part this is whatever the mike picks up from the room. The 15.631Hz tone goes up to -90dB. Still nothing to worry about, and like i said, it can be easily notched out if any processing done to the recording happens to bring it up. And like i said, this tone appears ONLY from my soundcard (Audigy SE, unfortunately i fried the onboard Realtek HD a while back), and not with any other source.
            I don't think it gets any cleaner than this on a piece of equipment where all I/O is unbalanced. The only thing is still needs is a little more oomph on the headphone amplifier - it is loud, but it distorts very easily on bass. And there's one more little thing - the PFL bus needs some tweaking. The master PFL switch needs a pad because it comes in too darn loud compared with everything else, and the PFL switches on the channels need to be rewired post-EQ. Otherwise, if i forget i flipped that bass cut switch, i've done the booboo, coz i can't hear it in the headphones, but everybody else can...
            • Wizard
              • Mar 2008
              • 2296
              15.6KHz noise needs to be found and fixed, not notched out. By the way 15.6 is very close to TV NTSC frequency (15.7KHz) or 625 line freq.
              Cheers, Wizard
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                I don't have a TV in my room. Maybe there is one in my soundcard.
                • Longon
                  Behringer Pro Mixer DJX-750
                  by Longon
                  Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                  Today, 02:17 PM
                • Bektronics
                  Schematic Digital Audio mixer RCF type M18
                  by Bektronics
                  Hello dear audio friends.
                  I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                  The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                  I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                  Thanks in advance if anyone can help me with this schematic.
                  Of course, all information about this digital mixer and possibly references...
                  07-24-2023, 06:40 AM
                • Thermaltake
                  Yahama mixer PSU difference
                  by Thermaltake
                  I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
                  I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
                  And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
                  I google a little and found that there is this part number...
                  09-17-2024, 11:52 AM
                • Thermaltake
                  Power button on Behringer Xenyx 1204USB mixer dead ?
                  by Thermaltake
                  Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
                  I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
                  08-16-2022, 03:22 AM
                • spleenharvester
                  GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                  by spleenharvester
                  I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                  07-08-2025, 06:02 PM
