12V input to 19V@3A output converter
  • Aruba
    • May 2010
    • 58
    Would like to build a 12V to 19V@3A converter. Basically it takes a car
    11-14V as input and provide a stable 19 +/-0.5V at 3A max to provide
    power for the laptop/notebook. Any such boost converter circuit available ?
    Aruba
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: 12V input to 19V@3A output converter
    There are those universal notebook adapters, some of them have a car lighter plug too.
    A working TV? How boring!
    • Aruba
      • May 2010
      • 58
      I know about those but I was more interested in building one myself. Found
      a boost controller from Linear Technologies (LTC3786) that supports an
      input voltage of 4.5-24V and output voltages up to 60V. There is a nice
      example of a 12-14V input to a 24V@3A design with some minor adjustment
      that should do what I need it to do.
      Aruba
      • flibidy
        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
        by flibidy
        I have here a Magnum IA.100 which belongs to my parents.
        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
        What Ive done........
        01-01-2025, 01:26 PM
        MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
        The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
        Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
        10-23-2024, 03:23 AM
        MT3608 Step-Up Converter IC Datasheet
        The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
        Internal soft-start results in small inrush current and extends battery life.
        The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
        10-07-2024, 05:02 AM
      • EasyGoing1
        Reading input and output of bridge rectifier on the same scope?
        by EasyGoing1
        I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
        When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
        06-26-2022, 12:52 AM
      • ugamazing
        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
        by ugamazing
        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
        04-10-2024, 08:06 AM
