right here is my problem i have a 50"phillips 7320 i need a new power board but they is a no go i cant find one but !!! i have come across one out of a 42 my part number is lj44-00108c ps504-ph. but the one i have found is lj44-00101c ps 424-ph all the plugs look the same apart for one which looks the same plug but a little bit more to the right than mine any help would be great thanks
42" 50" samsung power board
Re: 42" 50" samsung power board
They commonly have overheated driver mosfets.
Maybe a few bad capacitors too, I would replace all of them.
-BenMuh-soggy-kneeComment
Assuming...7 Photos -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by NicktronicHey everyone,
This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
Anybody... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
