"Ole blue" power supply
  • mockingbird
    • Dec 2008
    • 5484
    #41
    Re: "Ole blue" power supply
    Ok, turns out I had one of the voltage selection wires soldered in the wrong place...
    Checked the primary voltage again, one cap is reading 160+, the other is reading 0 volts. 5VSB still showing 0.
    edit:
    bah! I should have taken down better diagrams when I overenthusiastically took this thing apart years ago... I need an identical one to see which wire goes where exactly. Young Year was a bit quirky with the PCB labeling.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      #42
      It's a simple voltage doubler circuit. Just follow the traces on the board. One of the voltage selector switch wires should be connected to neutral right before the bridge rectifier. The other should be connected to the midpoint between the two caps (that is, the point where one of the main cap's (+) side is connected to the other main cap's (-) side).
      Also, check your bridge rectifier. Normally, a bad bridge rectifier would cause a fuse to blow and the chance of a diode going open circuit are next to none (but still, it is possible).
      • mockingbird
        • Dec 2008
        • 5484
        #43
        Ha ha... I finally got the thing working -- I think...
        One wire, as you said, between the two caps, and the second cap needed to be connected to the second leg of the bridge rectifier... 160V on both big caps and the most important thing, 5VSB voltage is present!!! Yay. Long live Young Year.
        Now I need to hook it up and see if it actually powers a computer up. Thanks everyone.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          I don't think I posted this ages ago, but out of the blue (pun intended?) it started running on the revised power rail setup... until maybe a year later or so (IDK how long) and last night she died.
          I don't know what happened... I'll investigate later. Stupid Ultra POS.
          sigpic
          (Insert witty quote here)
          • everell
            • Jan 2009
            • 1514
            What kind of computer was "ole blue" powering?
            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Intel DP35DP with a PDC, lower end GPU. The PSU was overkill.
              sigpic
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Were you still getting 5VSB?
                • everell
                  • Jan 2009
                  • 1514
                  That Intel board looks like a really nice board. If you have to retire "ole blue", I can send you "new blue" posted earlier.
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
                  • burntonnerings
                    Acer K272HUL blue power light but black screen, power supply is ok
                    by burntonnerings
                    Have had two Acer K272HUL monitors die with the same symptoms:
                    - Blue power light is illuminated while the monitor is plugged in
                    - Black screen (no splash screen, etc.)
                    - Power button doesn't do anything
                    Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                    Power supply voltages are fine.
                    There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                    Anyone have any ideas?...
                    12-09-2023, 10:22 PM
