why all the glue in PSU's?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Like the title says, what's the point of all the glue I see strung over EVERYTHING inside of most PSU's. Seems like the manufacturers go a little glue-happy at times!
    Ludicrous gibs!
  • Newbie2
    • Sep 2005
    • 885
    Re: why all the glue in PSU's?
    My dad thinks so that loose components in power supplies will survive shipping without being knocked off. There are lots of glue around caps with some power supplies, and that drives me nuts.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      The reson coils and caps are covered in glue is to eliminate the high-pitched tone they can otherwise create which is very annoying
      It's common for older TV sets to have this problem; the glue has after the years gotten solid and thus does not prevent the multi kilohertz signal from causing for example the ferrite core in a coil to start moving and creating noise...
      • Newbie2
        • Sep 2005
        • 885
        The Enermax EG301P-V 300W PSU I have lying around my house doesn't have any glue on the inside!
        My gaming PC:
        • arneson
          • Sep 2005
          • 1267
          I worked an assembly line job in a xerox plant, late 70's.
          Next to me was the power supply line, 30 women, soldering, glueing and talking a mile a minute.
          The glue was flyin around with the gossip.
          Jim
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            The glue is for mechanical stability, on lytics and on the toroid-core inductors. The switch frequency for modern switchers (late 70s onward) is above 20KHz, i.e. not audible (many current switchers operate above 100KHz).
            PeteS in CA
            • mitsu2k
              The Real Dangers of conductive glue.
              by mitsu2k
              I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
              Here is an experience I...
              04-16-2023, 06:29 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • AJ847.63e
              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
              by AJ847.63e
              Hi Folks,
              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
              05-06-2025, 10:37 PM
            • digtalhd
              Remove IC glue
              by digtalhd
              Hi!
              Anybody help me. Remove IC glue on mainboard.
              Thank you....
              11-08-2024, 02:25 AM
            • Al-Umar
              Need Help to dissolve glue
              by Al-Umar
              Please can someone tell me the chemical that can be apply to dissolve glue that used to hold the type C chip and SSD storage chip MacBook 2017 touchbar on the board.
              Please i need a prescription of that chemical. i will be very glad if someone can help me out on that
              05-04-2024, 07:46 AM
