Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
  • everell
    • Jan 2009
    • 1514
    Re: Power supply build quality pictorial
    I have a Raptor LC-B400 that looks very similiar to this psu. Does anyone know what the "chip of the year" marked 2005 is? I thought it had something to do with proprietary markings, the transformers also are marked with a number including 2005. I was not able to find a data sheet for the IC.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      master hoarder
      • May 2008
      • 12175
      #402
      Well I decided to name that IC "chip of the year" because the numbers on the IC seem to be somewhat related to the year the PSU was built. I took apart 2 L&C PSUs last year and from what I remember, one was from 2003 with the IC marked 2003, and another was from 2005 with chip and traffo marked 2005. But maybe that was just a coincidence.
      I think somone mentioned it on this forum before that those ICs are just cheap TL494/DBL494 variants.
      • cheese007
        • May 2009
        • 85
        #403
        Raidmax Aurora 2 "600w", have been told this is really just a 500w Andyson, and the box even advertises the fact that ripple on the 12v is barely in-spec, and that the ripple on the 3.3v and 5v is OUT of spec.
        • cheese007
          • May 2009
          • 85
          #404
          Old LCT Tchnology 250W AT PSU, must be at least fifteen years old, surprised it still runs.
          • cheese007
            • May 2009
            • 85
            #405
            Dell 160W Optiplex GX-270 slimline PSU. Still works great.
            Pic of the OST primary caps.
            Austin 280w PSU, infected with capacitor plague, had some cool multi-color fans that I ripped out of it.
            Primary caps.
            Failed caps, one had electrolyte leaking out of it.
            This has been silkscreened for about a billion different designs.
            Yay chip of the year!
            Powertech 200W PSU, pulled out of a Gateway G6 333
            Rubycon primaries.
            Delta could be the OEM, don't know for sure.
            Dell 200W, pulled out of an 11 year old Dimension, seems to be of high-quality, too bad it's got that stupid DELL wiring, any way to use this on a standard ATX mobo?
            Primary caps.
            Lite-on OEM
            • Krankshaft
              • Jan 2007
              • 2328
              Whoa the images are so large I can't see anything.
              Can somone reduce those please it's throwing the forum frame size off.
              I usually reduce my pics in Paintbrush when I'm lazy.
              Control W
              Stretch:
              Width: 70
              Height:70
              Then again Control W
              Stretch:
              Width: 50
              Height: 50
                master hoarder
                • May 2008
                • 12175
                #407
                I agree, pics a pretty big. My internet explorer 6 is eating away 407MB of ram .
                Most likely, yes. Either rewire the Dell 200W mobo connector so that it has the same wiring as a standard ATX connector or desoldier another ATX connector from a junk PSU and soldier that in the Dell 200W.
                • everell
                  • Jan 2009
                  • 1514
                  cheese007 > See thread "Old Dell PS 5201-7D 200 watt psu" posted in this forum 2-10-2009. A good discussion on this non-standard wiring configuration, what you can do, and website information giving the color codes for the wiring.
                  I have one sitting on the shelf - will probably use it for parts - too much trouble to rewire.
                  Tom
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    Last edited by Scenic; 06-12-2009, 07:42 AM. Reason: err.. *del* and -> discussion thread
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      Delta dps-300kb-1 A
                      12V @ 15A
                      5V @ 30A
                      3.3V @ 26A
                      not terribly efficient, non-APFC, group regulation, but running a p4 1.7ghz Willamette on a asus p4t motherboard with 1 20gb hd, cd rom, and a pci radeon 7000 it was reading 11.91V, 5.01V, and 3.24V.
                      • jvyt
                        • Feb 2009
                        • 11
                        #411
                        Micase WR300
                        Micase WR300
                        Jee everywhere:
                        Jee 330uF 200V (CE.W, 85C)
                        Jee 1000uF 10V
                        Jee 2200uF 16V
