FSP Blue Storm Bronze 500 sleeved cap ?
    Anyone has opened this unit yet?
    Is that a sleeved Teapo ?
    Re: FSP Blue Storm Bronze 500 sleeved cap ?
    A Y vent with 3 tick marks I would say it's a Teapo.
      Yes. If it has a y vent with 3 dots its definitely teapo.
        Is the sleeve to protect against heat we reckon?
          yes because that cap is almost touching a hot switching component
            Are you sure?
            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
              Looks more like its wedged right inbetween a diode pack and the 5vsb transformer.
                Is not for heat. - Is for electrical insulation.
                The sleeves are not intended to be electrical isolation.
                Mann-Made Global Warming.
                - Dr Seuss
                  i thought all those black things on psu were called "switchers"? i didnt know there were different kinds
                  can u explain what different of those black things there are and what they do?
                    The ones on the secondary heatsink are generally two schottky or ultrafast diodes in a to-220 or to-247 package. They convert the 12v and 5v (as well as the 3.3v which is derived from the 5v through a mag-amp circuit) AC current from the transformer into their DC voltages. Though modern power supplies that use DC to DC for the 5v and 3.3v use VRM's to convert the 12v into 5v and 3.3v.
                    The primary switchers take the ~320-380v (depending on the topology, presence of APFC, etc...) DC on the primary and convert it into AC current and feed it to the primary transformer.
                      FSP put heatshrink on caps a lot - i'v seen it loads of times.
                        Teapo is the capacitor that helped save america, nothing to worry about.
                        My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
