Desoldering station ZD 915 no indications, no heating
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello all,
    I tried to power on my desoldering station ZD915 today and altough the LCD has power and it's on I don't have any indications on the screen and the gun is not heating at all.
    I open it up and I don't see any visual fault anywhere.
    Does anyone has any clue what should I check?
    • 31090
    Re: Desoldering station ZD 915 no indications, no heating
    check the module with the display is getting or generating 5v
    there's several internal variations, post foto's and i can probably give you schematics
    • lotas
      • Jan 2016
      • 4661
      • Russia
      Here is a topic similar to your problem.
      https://www.iwenzo.de/threads/zd-915...lay-tot.55914/
        • Jul 2011
        • 6046
        Are you saying that the back light is on but the screen is blank if this is case I personally have not run into this issue ( however I would check and see if you have 20 volts or so and you should also have a 5 volt rail as well also check that there is nothing on the controller board is that is heating up because I have seen before that the surface mount capacitors have been an issue before I have had this issue before but in my case it was a non stable gun temperature )
        Here is what you need to check
        Do you have a temperature on the screen that is for the gun or is it “———“ if you have this then you have an open temperature sensor wire
        If you have a temperature reading what is the reading and is the “heat” on the screen ( if the “heat” is not on the screen then ) ****if not then you have an issue with the controller board which ****I have not seen this issue before
        Dose your gun get hot even though you have no temperature reading
        When you press the suction button does it start the pump if not then you might have a controller board issue or you have a bad wire cable or a bad switch
        Or the scr or mosfet issue
        You need to post a picture of the screen when powered ON and when you first turn it ON so I can see what version board you have because not all versions behave the same way
        I have about 6 to 8 of these desoldering stations and I have several different versions of this device I have repaired them in the past
        I hope this helps you get started with troubleshooting this issue with your desoldering station
        • rippergr
          • May 2014
          • 345
          • Ελλάδα
          Exactly like that. The backlight is on and I have no indication. Not even when I turn it on.
          The gun doesn't heat at all and when I press the button the pump is working.
          As you can see in the pictures the desoldering station is as new.
          I have used it about 20-30 times.
            • 31090
            check the input and output of the 5v regulator 78L05
            also there is a zener diode after the 5v to reduce it to 3v - check that too
              • Jul 2011
              • 6046
              Also there is a 5 volt that is in the switching power supply you need to make sure that you have this 5 volt rail and there is also a 5 volt rail that Stj mentioned in his post above
              I do not remember what color wires they are but you easily spot which wires they are if you take off the metal enclosure there is a high wattage resistor and a Zener diode it is in a weird configuration just make sure that you have at least 5 volts if I remember correctly it is the -5 volt rail
              Check and see if you have voltage on the micro controller ic chip ( is the one has a lot of pins ) which is on the controller board to find which one it just google it the part number one will be the display ic chip and the other one should be the micro controller ic chip
              There is a remote possibility that the display it self is the issue or the display driver ic chip
                • 31090
                if it was the display driver the iron would heat up though
                • redwire
                  • 3910
                  I would pull the control board and do a visual inspection.
                  I see rust? or slag on U5 pad. They swapped in mini-melfs for DA1, DA2 but need a huge blob of solder to reach now. It's an ancient chinese trick to use huge PCB footprints and put in way small components, but the solder doesn't always stretch. Like R2, is it soldered on the one end?
                  Some soldering is suspect.
                  Check the PSU voltages supplied to the board like 5V and not sure where the 24V heater switch (mosfet) is located.
                    • 31090
                    i think the heater switching is in the psu
                      • Jul 2011
                      • 6046
                      The location is one of two ic chips that has three pins I do not remember if the one on the left side or the one in the middle
                        • Jul 2011
                        • 6046
                        It is however it gets the turn ON signal from the microcontroller on the controller board
                        The question is does the vacuum pump function when the trigger switch is pushed if not then something is wrong with the switching power supply or bad wiring or bad switch
                          • 31090
                          pump runs - re-read the thread
                          • rippergr
                            • May 2014
                            • 345
                            • Ελλάδα
                            The voltage in 78L05 is 5v and 14,5.
                            In Zener Z1 is 3,3v
                            I have attached a more close picture of the board.
                              • Jul 2011
                              • 6046
                              In Zener Z1 is 3,3v
                              Look at the soldering joints that are circled in red
                              • rippergr
                                • May 2014
                                • 345
                                • Ελλάδα
                                I resolder all the joints but nothing changed
                                • rippergr
                                  • May 2014
                                  • 345
                                  • Ελλάδα
                                  I have changed the Voltage regulator 78L05 and TL431A regulator but I still have the same problem.
                                    by sam_sam_sam
                                    03-31-2024, 02:12 PM
                                  • armini
                                    18VDC PSU completely dead - ZD-915 desoldering station
                                    by armini
                                    Hi everyone!
                                    Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                    Due to a lack of time, I set it aside and didn't look at it.
                                    Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                    According to replies in 18VDC PSU has dropped to...
                                    04-25-2023, 07:49 AM
                                    by sam_sam_sam
                                    07-01-2024, 06:34 AM
                                    HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                    This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                    09-12-2024, 02:20 PM
                                    MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                    09-07-2024, 05:20 AM
