Sony HCD DZ280 PSU
  • michel74
    • Oct 2023
    • 8
    • Switzerland
    Sony HCD DZ280 PSU
    I'm having an issue with PSU;
    When I had it in hands the resistor fuse FR929 (1Ohm) was dead. IC921 (MR4020 - Switching reg.) was dead too.
    I replaced both; when plugging the AC cord, nothing goes wrong. When switching On the equipment, the display shows something for few sec, and FR 929 blows again. Not sure if IC921 was still ok, so I replaced both again (...)
    Now, when I plug the AC cord, ... FR929 blows directly.
    When I measure resistance between pin 3 and 7 (Gnd and Vin) of IC921 I have less than 1 Ohm ... So, I changed it again (IC921) but still this low resistance
    Both D921 and C921 are Ok
    I'm a bit (completely ?) lost.
    Thx in advance
    master hoarder
    • May 2008
    • 12175
    Re: Sony HCD DZ280 PSU
    Check C924 and D946 for short-circuit and R916 for open-circuit or higher than normal resistance. Probably best to remove D946 from the circuit to get accurate readings. Also check R922 (0.18 Ohms) for open-circuit.
    lastly, if you have an ESR + capacitance meter, check the small electrolytic cap C912 or just plain-replace it... though this being a Sony PSU, I imagine it's a Rubycon, Nichicon, United Chemicon, or some other OK Japanese brand and may not be bad. But nevertheless, this is the "startup" cap and can sometimes cause a lot of issues.
    C926 should be checked as well. Also Zener Diodes ZD901, ZD902, & ZD904 for short-circuit, along with D902. Q922 too, if you can.
    To prevent further blow up of FR929 and the IC while testing, build yourself a "dim bulb tester" with an incandescent bulb. Details here:
    https://www.badcaps.net/forum/showpo...4&postcount=70
    ^ Start with 40W bulb, but go up to 60-100 Watts if PSU "hickups" (we will get to that part later only if it happens.) I know incandescent bulbs are not sold in the EU anymore, but you can still find 40W ones for appliance / baking oven... and in such case, with lack of higher power bulbs, 2x 40W bulbs in parallel will get you the equivalent of an 80W bulb.
    Anyways, check the components above and let us know what you find.
    • michel74
      • Oct 2023
      • 8
      • Switzerland
      Thanks momaka, so I went around looking for some bulbs and ... hard to find. I will to the test tonight
      Most of the tests you ask to performed above were already done, but I re-checked the component.
      C912 was showing 40uF instead of 47uF, but I replaced it for the other tests, everything is ok.
      I wanted to make some continuity check around IC921, but because of the very low value of R922 (0.18Ohm) the tester always bips between pins 3 and 5; and between pins 7(Vin) and 9 (Drain), I have a very low resistance (0.5 ohms) <= I don't know if its normal ...
      Thx
      • michel74
        • Oct 2023
        • 8
        • Switzerland
        A short update ...
        After having burn some other fuse resistors and other power IC module, I finally managed to "build" (assemble ?) this "dim bulb tester" as suggested by momaka.. and it definitely helped !
        After replacing the fuse and the IC (I think I burned 6 of then ...), when the PSU was powered on, I had no specific issue; but when plugging the main board to it, the bulb was ... blinking. This was a good sign to say that a cap was going mad somewhere;
        When I was testing the DC value at the main cap, I was having the 320 Volts ! So I never thought about testing it while PSU was connected to the main board; when I tested it, I only had ... 218 Volts. I had a quick look in the old PSU I was keeping for parts, removed the 330uF/400V cap, tested it (it measured ... 1 to 50 uF varying) so I replace it and ... it worked !
        This main cap was the issue, and I never thought it was, because when looking at it ... it looked perfect. No damage, no domed, or swollen top​.
        Well, just a simple message to say that, without this bulb, I wouldn't have found it before ... month (well, before getting to the point that the last component to change is this nice looking cap)
        Thanks again
          • Jul 2011
          • 6069
          I use an incandescent light bulb when I have switching power supply that is having issues or I do not know what the history of it is
          Yes an incandescent light bulb is definitely your friend for troubleshooting a lot of things that are blowing fuses or tripping breakers and if an incandescent light bulb does not have the wattage you need you can even use a heater element instead I personally have not done this yet but I am going to build a jig for one out of toaster oven I just have not needed one so far but if I had one built I would be using right now because I repairing quite a few switching power supply that I have a post about on this forum
          One note just because a capacitor is not swollen or leaking dose not mean that it good it might have a very high ESR reading I am a little different than members on this forum when I test a capacitor with a ESR meter and it's reading is close to double what a new one reads I just replace it especially if it is lower than 100uf but that is just me partly because I have the lower UF capacitors in my part bin anyway and generally they are not that expensive when you buy 100 of them at a time up to 47uf any higher value than that I will only buy 10 or 20 of them at a time depending on how much they are and how many you have to buy for a price break on each one
          One other note if you are going to repair switching power supply you really should consider buying a ESR meter for troubleshooting them
          • cind12
            GTX 1080 TI Gigabyte Aorus low resistance on vmem
            by cind12
            Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
            Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
            The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
            Resistance on 12V 4K ohms (Power present when on)
            Resistance on 12V PEX 4K ohms...
            12-08-2023, 09:09 AM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:27 AM
