Re: 12V 10A CCTV camera system power supply pulsating
It was not supposed to change, But did D2 provide any voltage to charge the temporary cap I asked to connect to the disconnected D2? If the temporary cap DID charge, then the feedback winding, d2 etc is working, and the problem is else ware.
Ok, bad news, pulsing as usual - no change
Only time it doesn't pulse in my previous experiences is when C4 is out of circuit....Leave a comment:
ok, so here goes!Leave a comment:
Should I remove C4 ?Leave a comment:
There is no need to remove the transformer, the feedback winding can be checked when D2 is out of circuit, The reason I suggested to add a cap to D2 so it can charge and give a proper voltage, basically it is acting as C4, so use C4's ground. Hot ground is the primary ground, basically the main filters negative lead or U1 pin1.
By isolating u1 pin7 we can check the transformer winding, the 22Ω resistor and D2 to make sure it is supplying voltage.Last edited by R_J; 10-11-2023, 08:58 PM.Leave a comment:
Ok, so just to make sure I get this right, I place a 10uf cap between D2 cathode and hot ground (what is hot ground, is it primary ground or same ground as pin 1 - dumb question) ?
Also R_J, I did have another D2 diode that I scavenged from old boards and exactly same behavior. I tested both with my fluke multimeter in diode mode and both test good.
Another question R_J, should I remove the transformer to check the feedback coil? What if it gave me the wrong reading because it was connected in circuit?Last edited by rddube; 10-11-2023, 08:12 PM.Leave a comment:
So nothing changes in the operation of the power supply if D2 in in circuit or not? if that is the case the feedback circuit can't be working.
With D2 anode connected and the cathode in free air, check if there is any voltage on D2 cathode, or if you can, place a 10µf cap between hot ground and D2 cathode and see if that circuit charges the cap. basically have u1 pin 7 disconnected from the circuit.
If you have another diode try replacing D2 it might be failingLeave a comment:
D2 removed, pulsing on the secondary output and on pin 7 of the PWM, pulsing from 11V to 15V approx. For the next test (disconnecting the optocoupler on the primary) do I reinstall D2?Leave a comment:
C4 needs to be in place or the ic will never ever try to start. If you disconnect D2 and the pulsing stayed the same then that could be where the problem is. I suspect the pulsing will stop as a result of no run voltage from the feedback winding.
I re-read that post #19, seems a long time ago, so the winding is not open.
I would try disconnecting the optocoupler on the primary side to see if you get closer to 12v on the secondary output. It may not work due to all the safety features of this ic.Leave a comment:
You can NOT feed an external voltage to pin 7, If you connect an external power supply ground to this power supply HOT ground you will blow it up.
Disconnect D2 and see if you have the same pulsing problem, and the voltage on pin 7 stays the same, if it does I suspect either R7 or the feedback winding on the transformer could be open.
The gate drive PWM is operating at 65KHz how do you expect to see a change in duty cycle with your meter?
I would try unsoldering the primary side of the optocoupler and see if the voltage on pin 2 is at 6v, and be careful not to short the ic pins when checking.Last edited by rddube; 10-11-2023, 04:43 PM.Leave a comment:
I would try unsoldering the primary side of the optocoupler and see if the voltage on pin 2 is at 6v, and be careful not to short the ic pins when checking.Last edited by R_J; 10-11-2023, 03:35 PM.Leave a comment:
With C4
Pin 1: GND
Pin 2: .1V to .3V oscillating
Pin 3: 16V to 19V oscillating
Pin 4: 0V to 1.3V jumping around sometimes to 3.2V
Pin 5: same as pin 4
Pin 6: 0V, sometimes shows .1V or .2V then 0V
Pin 7: Oscillating between 11V and 15V
Pin 8: .001V
Without C4
Pin 1: GND
Pin 2: .11V steady
Pin 3: 18V steady
Pin 4: .1335V steady
Pin 5: .323V steady
Pin 6: .044V gradually decreasing to .038V
Pin 7: 13.77V steady
Pin 8: .013V
Pin 7 vdd needs to be at 16.5v or above for the ic to operate
How to isolate the problem - I dont know if it is right way, but grand masters are watching and can correct meDo not anything without their aproval.
I will desolder D2 and feed 18V into pin#7. With this can be isolated eventualy problem on aux windings. You may observe current draw also.
Second, if first idea do not work upgrade to second idea - desolder secondary output diode and feed output of psu with 12V, to check feedback. When you adjust trimpot, some changes must see on primary side, eg change gate voltage in AC mode.
Double check R4 and R6 on gate.Leave a comment:
PWM:
Pin 1: GND
Pin 2: .11V steady
Pin 3: 18V steady
Pin 5: .323V steady
Pin 8: .013V
btw, C4 is a 10uf 50V cap changed from the original for a very low ESR cap. It was not present on the board during the above test.Last edited by rddube; 10-11-2023, 01:40 PM.Leave a comment:
That datasheet shows the TOP VIEW of the ic, not the bottom view, The reference pin does not drive the optocoupler.Leave a comment:
I also think I identified the reference and the cathode correctly, because if you turn the board around, that's how it is positionned.
And maybe another point, I not sure:
What is weird, is when I remove C4 and test, I get no more pulsing on the top pin of R10 (a nice clean stable 18V), but then I get no output on the secondary side, nothing?Last edited by harp; 10-11-2023, 11:50 AM.Leave a comment:
It is a AZ431 which I think is the same. I also think I identified the reference and the cathode correctly, because if you turn the board around, that's how it is positionned. I'll check R13, R14 and the 0ohms at loc ZD2 and report back.Leave a comment:
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by madan1Good day.
I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar... - Loading...
