12V 10A CCTV camera system power supply pulsating
  • rddube
    replied
    Re: 12V 10A CCTV camera system power supply pulsating
    Installed a third TL817 (correctly) and doing the same thing, this time pulsing from 3V to 6-7V with sometimes showing 4V - 5V erratically.
  • rddube
    replied
    Originally posted by lotas
    The reference voltage for tl431 is 2.5v
    And install the TL817 ortron correctly (1-2 pin on the cold side, 3-4pin on the hot side).
    Hi, it was installed correctly, it is me that reversed the reading. And when installed (correctly), we are back to square one whereas the output pulses between approx 4V to 6V-7V.
  • lotas
    replied
  • rddube
    replied
    Ok, so I double checked to make sure I am giving you the right pins on the AZ431 (TL431), this is with the optocoupler out:
    Reference: 2.6V steady
    Anode: OV
    Cathode: 1.8V steady
    As a double check, I reproduced them (in yellow) on the photo attached (the adjustable resistor is in place however).
  • rddube
    replied
    Originally posted by R_J
    The TL431 is the voltage reference ic. And the EL817 optocoupler is installed with pins 1&2 on the secondary side, correct
    From post 19
    This should not be enough voltage to turn on the optocoupler led, and cause E-C to conduct.
    What are the voltages on the reference ic with respect to ground
    I'm terribly sorry, I was looking at this upside down again and got things reversed. Really really sorry, I'll make sure I double check before writing stupid things. I'll get the voltages on the TL431 (the right ones) and report back. Thans for your patience.
  • lotas
    replied
    Originally posted by rddube
    Oh R_J, this power supply has the pins 1 & 2 of the optocoupler on the primary side! That's how it was installed originally, the small dot being the pin 1 ?
    It is not right.
  • rddube
    replied
  • R_J
    replied
    From post 19
    Finally, measured voltage on secondary side of optocoupler which oscillates between .1V and .6V-.7V
  • rddube
    replied
    Sorry R_J, but is the TL431 the optocoupler - in post #6 it is talking about TL431? The original optocoupler is the one in the first photo (a bit blurry but it is EL 817), I had replaced it with the one in the second photo with same results.
  • R_J
    replied
    The pot is there to adjust the 12v output, try adjusting it.
    In post #6 you were asked about the optocoupler and said
    No, but I did pull it out and tested it with my component tester and it tested good
    What is the number on the optocupler? It is installed the correct direction as I can't see it clearly? I would replace it
  • rddube
    replied
    How much effect does adjusting the 1K pot have on this power supply?
    I don't really know, I have never adjusted that pot in the past. I tried looking for a schematic but I don't think any exist?
    In my reasearch I did find this video, but I think we've tried most of that:
    https://www.youtube.com/watch?v=YbUftLuvODg
  • R_J
    replied
  • rddube
    replied
    So something on the secondary side around the reference ic is likely the problem, When the opto coupler is connected, it pulls pin2 of U1 low puting into burst mode.
    What is that stuff on C6, the blue disc cap?
    It's some sort of glue, you can see the same stuff on the back of the power supply where the screws are. I checked C6 (unsoldered it) and it measures good. I didn't unsolder C10, but I could if you think that could be the problem?
  • R_J
    replied
  • rddube
    replied
    Had changed the AZ431 (post #35). Pin 2 is showing erratic voltage between .101V to 5.9V jumping in between just like for the 12V output mentionned in post #66.
    Thanks for hanging in there R_J!
  • R_J
    replied
    So it would seem the regulation for the optocoupler is causing the problem, can you change the AZ431 (TL431 etc)
    Is Pin 2 of the ic sitting at around 6v when you tried this? My guess is the optocoupler led is being turned ON causing the photo transistor on the primary side to conduct shutting down the ic. A bad reference ic could be the cause.
    My guess when the power supply is working properly, pin2 FB would be around 2~3 volts
  • rddube
    replied
    Everything put back together, optocoupler unsoldered on primary side, I get erratic from 14V to 21V and anywhere in between on the 12V ouput.
  • rddube
    replied
    ok will do and report back.
  • R_J
    replied
    I would put things back as they were and try unsoldering the primary side of the optocoupler and see what voltage you get on the 12v output, this may not work because of the ic protection circuit. Something is telling that ic to be in burst mode. There are not that many components that can cause this.
  • rddube
    replied
    It was not supposed to change, But did D2 provide any voltage to charge the temporary cap I asked to connect to the disconnected D2? If the temporary cap DID charge, then the feedback winding, d2 etc is working, and the problem is else ware.
    Ok R_J, you are right I just forgot why we were doing this test (getting old I guess ). Ok, so yes the cap charges very well up to 13.2V very steady and when I remove mains power, cap discharges gradually but very slowly.
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
