12V 10A CCTV camera system power supply pulsating
  • rddube
    replied
    Re: 12V 10A CCTV camera system power supply pulsating
    Originally posted by harp
    Is this one from attach?
    Please write the reading you get on each coil, say 3 red, 1 yellow...
    So, it is 3 coil
    Primary main
    Primary aux
    Secondary out
    What is resistance of each coil, and value of ring tester, and if you have transistor tester for inductance...
    Suspicious is primary main coil...
    Secondary output coil may have only few turns and appear in short?
    Yes that is the blue ring tester I have. Attached are photos of the primary and secondary side of my transformer. Can you pinpoint where I should measure?
  • harp
    replied
    So, it is 3 coil
    Primary main
    Primary aux
    Secondary out
  • rddube
    replied
    That's o.k. Can't be worse than a Effed up measurement. You just have to know what windings are where and on which side and you have to measure one winding to the other winding etc. One more test you also could do is an insulation test on the transformer. Maybe it's looking good like that, but starts arcing when under higher voltage? I don't have a ring tester, but I do have a 1000v Isolation tester.
    Ok, so I took the transformer out. The winding which is the feedback winding on the primary side looks fine with the blue ring tester. The other winding on the primary side comes out as a short, but then all windings on the secondary side all show up as shorts (there are 3 legs connected together and 3 other legs connected together, if I measure between both 3 legs, it shows up as short.).
    Do I have to disconnect the 3 legs connected together before taking measurements?
  • CapLeaker
    replied
    That’s o.k. Can’t be worse than a Effed up measurement. You just have to know what windings are where and on which side and you have to measure one winding to the other winding etc. One more test you also could do is an insulation test on the transformer. Maybe it’s looking good like that, but starts arcing when under higher voltage? I don’t have a ring tester, but I do have a 1000v Isolation tester.
  • rddube
    replied
    At the end of the day it isn't that wild, because it is just a singe voltage PSU. You can always replace it with a different one. To me there is somewhere something open or high resistance, or the transformer got a shorted winding. To measure the transformer you need a ring tester, you can't measure its resistance besides an open.
    I do have a ring tester but not too sure how to use it. Also, I've been told that they are not that accurate, but it's the one that you build with a kit. I could with some guidance test the transformer - it's got 2 X 3 connected legs on the secondary side and 4 legs on the primary side.
  • CapLeaker
    replied
    At the end of the day it isn’t that wild, because it is just a singe voltage PSU. You can always replace it with a different one. To me there is somewhere something open or high resistance, or the transformer got a shorted winding. To measure the transformer you need a ring tester, you can’t measure its resistance besides an open.
  • harp
    replied
    Originally posted by rddube
    I'm about to give up on this thing unless any of you have any other ideas, I think we spent enough time trying to resolve this. Many thanks to all of you!
    I think that your chip have no needed voltage to operate in pin7. So how about that you disconnect primary aux diode and connect 2x9v battery (18Vdc) on that resistor for pin7. Wait aproval if this idea will provide power to ic to test.
    If is all component around the board is ok, that only left a transformer. Inductance can measure with "transistor testers", when is out. When you choose to step ahead to rewireing it, know that this not impossible, and also reffer to repair electronic...
    https://m.youtube.com/watch?v=ODcqLmg7vR4
    replied
    22 or 47uf would be better
    but check the related diode too
  • rddube
    replied
    I was thinking in putting in a 1uf cap instead of the 10uf cap. What do you think? Usually, startup caps are 1uf 50V, so maybe this could be the problem because when I put a 47uf cap it just didn't make any difference.
  • rddube
    replied
  • rddube
    replied
    another thing is have the bad solder joints been rectified yet ? i see a few on the first pic .
    Yes, I redid almost all the solder joints.
  • rddube
    replied
    My suggestion is, that all the time that going with testing and troubleshooting, you have permanently soldered dummy load on output, say 100R few wats. When you find the problem, voltage will arive on output, otherwise, without load may pulsate anyway.
    Notice down first initial measurement of this setup, voltage on (loaded) output, for future reference.
    Somebody earlyer suggested to connect larger capacitor on pin7. To dont overbutched your pcb, try to add temporarly parallel biger and bigger caps on other side direct on solder points, or use fine aligator clamp. Monitor output, if any change and compare?
    Also, on your post #102 when took off transformer, have you write readings of resistance and inductivity?
    Ok, so tried with a load, no output at all. Without load, pulsating from 4V to 6V.
    Tried a 47uf capacitor, still same result - with load no output, witout load pulsating between 2 - 3V.
    When I took off transformer I did not write resistance but I checked and it all seemed good. Don't know how to check inductance however.
    replied
    am sure this will have been looked at already in the pic .
    on another thought i dont really understand this circuit but i might have expected the gate of the chopper transistor to be getting something other than 0v . Pin 8 - 9.54kΩ to ground .is this ok ?
    that image is the winding to power the chip once running.
    thats why i asked about that diode on pin7
  • petehall347
    replied
  • petehall347
    replied
  • CapLeaker
    replied
    Ok, redid the test and here is what i get when I inject 12v at the output:
    TL431 Reference 2.6V
    TL431 Cathode 1.8V
    opto pin 3 & 4 no power : .680M ohms
    with 12 V on output: 105 ohms
    That's what I was looking for earlier. There isn't much more to proof that the secondary is o.k.
    You got the primary and the transformer still as suspect.
  • harp
    replied
    TL431 Cathode 1.8V
    Now opto look ok, so it is prove that led and transistor worked.
    For TL431, I guess it is also ok, but not sure.
    I highly suggested that you use a bulb current limiter always when troubleshooting with live mains.
  • rddube
    replied
    was the ic changed for a new one yet ?
    Yes the IC was changed for a new one.
  • rddube
    replied
    It is not neccesery to remove secondary diode again, unless (like I mentioned before) you feed 12Vdc to output and simultaniously power psu from mains 220Vac, due to specific testing purpose.
    So yes, just feed 12v and check again pin1&3 of TL431 and primary side of optocoupler, maybe to try reverse probe, or other dmm... if in off state is 3k reading accross pin3&4 of opto, then when interLED power on must be some lower reading, dont you think?
    TL431 Cathode 1.8V
  • petehall347
    replied
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
