unite caps in mge vigor 400,apower misc models
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    have been seeing lots of these mge gamer special vigor psu's with these unite brand caps.
    a power uses the same board on a plain case.
    seems to be the same board as powmax.
  • Rainbow
    • Aug 2005
    • 1375
    Re: unite caps in mge vigor 400,apower misc models
    I think I've seen something like that today in Gembird (really crap brand) PSU (made 2004).
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      some sites confuse them with MGE UPS SYSTEMS they are in my bad books anyway but time to sue for passing off?
      unite eh? another difficult name for google searches.
      • japlytic
        • Oct 2005
        • 2086
        I've seen this 'Unite' brand electrolytic capacitor before. Also, I have seen a 'United' brand electrolytic capacitor as well.
        I guess the CD110 and CD263 and CDxxx series are used by more than one Chinese manufacturer - they are usually of poor quality...
        The 'Gembird' manufacturer can be found www.gembird.cn - they also manufacture UPS units as well - would you trust them with their UPS units?
        • Rainbow
          • Aug 2005
          • 1375
          Personally, I wouldn't buy Gembird UPS. I have two things from Gembird and both are bad:
          FlexiDrive - USB 3.5" HDD rack - sometimes works, sometimes not. They left out a small watchdog chip that should reset the controller so it detects as unknown device sometimes. I used it very rarely, but the handle of the plastic rack broke despite that...
          KVM mechanical switch - the wires inside were very bad, resulting in ghosts on monitor - so I replaced RGB with proper shielded cables (cut from monitor cable), then after about a month of usage, the switch started to fail and sice I like all RGB colors on my screen, not only some of them, I had to throw away everything from inside and build a simple electronic switch there (3 relays for RGB and CMOS switches for the other signals).
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
