I need an AC transformer because the one I used is burned. Since I have some unused DC transformers, I wonder if it is possible to just remove the bridge rectifier from it to convert it to an AC transformer. I measured voltage before the rectifier on this one - it shows 13 VAC, and 16 VDC at connector without load. Rated 12VDC 1000mA.
Converting 12VDC transformer to 12VAC
Re: Converting 12VDC transformer to 12VAC
a lot of electronics that require AC actually have a bridge rectifier installed inside and the brick is AC( like a modem). If there is a bridge rectifier in that piece of electronics you are trying to plug in, just plug in the DC transformer. Polarity doesn't matter, since the bridge rectifier inside the electronic piece is going to take care of it.Comment
This is not for electronic devices, just LED lights. I know it sounds weird since LED is meant to work with DC
I have a set of garden lights, originally the wiring and power were for old iridescent bulbs, during the years I had it I changed it to LEDs, added more, replaced some, etc. A lot of it soldered to wires. I never paid mind to polarity since it still worked from the original AC transformer. But lighting killed the transformer after many years. I replaced it with another AC transformer. But one rodent chewed wires under the porch (not buried), at the soldering point. Not sure why. It had heatshrink tubing with adhesive on it - does anybody have any idea why the rodent likes it? I have a field near my house, blueberries, etc - Im sure herbivore creatures can't be that starving in the summertime. Anyway, it shorted wires and destroyed the transformer. I can resolder all wires to proper polarity and use a DC adapter, but this will be too much hassle and time-consuming. Getting an AC transformer is a lot easier at this moment (maybe one day I will get to it
I removed the rectifier from that DC transformer, and connected it to the lights - it reads 12.6 VAC, 0.42A (measured with a fluke clamp meter). One that the rodent killed was rated 12VAC, 1000mA, and connected to lights measured 14VAC, 0.50A. Is it OK to use it?Last edited by sansonet; 06-30-2023, 07:41 AM.Comment
I would caution you against leaving it this way if you plan on keeping it plugged in the outlet 24 hours 7 days a week 365 days a year
If you plan on using it like that put another thermo fuse back in for safety reasonsComment
I do not know what possess rats to be attracted to low voltage wiring but they are I have seen this a few times in the pastThis is not for electronic devices, just LED lights. I know it sounds weird since LED is meant to work with DC
As far as the question about the replacement transformer probably be ok but make sure that you are not over driving the LED lights current because as you know this kills them earlier than was intended even if this means that you put a current limiting resistor on each LED circuit
Those transformer that you have in the picture above are terrible about over heating when loaded lightly I have some of the same type and I personally do not use them other than for testing purposes onlyLast edited by sam_sam_sam; 06-30-2023, 06:31 PM.Comment
Of course, I will not use it without a fuse, already ordered one. Im using a photosensor switch so it gets power at night only.Comment
Not rats, I don't have rats here. We have voles, field/deer mice, and rabbits. It happened in the daytime. Definitely rodent because it has teeth marks.Comment
I soldered thermal fuses in the past, no issues so far. Im using those clips when dealing with heat-sensitive components - it helps a lot
https://www.amazon.com/H-2SL-Goot-He.../dp/B001PR1KNS
I ordered a pack of 10 anyway - a lot of spares if something will go wrong
by mikey5791Hi all,
Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
My questions are
1. How do i test to see if the transformer is in good working condition?
2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
Hope you guys understand what i was asking. My intention is... -
This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 04:40 PM
This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 12:00 PM
This specification for the ASUS Transformer T304UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA boardview and T304UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...09-06-2024, 11:50 AM
This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 11:50 AM
- Loading...
