iMac G5 PSU
  • Kelly889
    • Sep 2010
    • 8
    iMac G5 PSU
    I just replaced two caps in an iMac G5 PSU - model 614-0325. I checked the open circuit voltages and they are not the same at standard ATX supplies. In particular, there is a +24 line which I didn't expect.
    I found this site by Googling for 614-0325 pinout. There's a thread with that supply as the topic and it seems that 24V is an expected voltage.
    Can anyone point me to where I can find more info on what voltages to expect on what pins and how to turn the PSU on without installing it in the comptuer? I'd like to check it out before putting the PSU back in.
    Thanks,
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: iMac G5 PSU
    unfortunately apple had to their proprieatary shit and i dont think the normal way of shorting the green wire to black in a pc atx supply would work with your power supply...
    • Kelly889
      • Sep 2010
      • 8
      Re: iMac G5 PSU
      Thanks,
      When I looked at the connector and realized that it looked like a standard ATX and that the grounds were the same, I was hopeful that it was a standard ATX pinout. However, when I saw 24 V on one of the pins, I knew different.
      Still searching for the pinout and how to turn this PSU on outside of the box.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Re: iMac G5 PSU
        is there a green wire in the main connector? sort of near the middle in the top row?
        • Kelly889
          • Sep 2010
          • 8
          Re: iMac G5 PSU
          No green wire
          - the wires are mostly black and grey.
          - There are 4 brown wires and:
          - blue wire in pin 7
          - purple wire in pin 8 showing me +5V
          Pin 14 shows +5V
          Pin 20 shows +24V
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Re: iMac G5 PSU
            so this is the standard atx pinout:
            http://www.subedartech.net/docs/pc/c...atx_pinout.GIF
            and im assuming your psu looks somewhat like this:
            http://lh3.ggpht.com/_hsvnxFEc2do/Sf...jpg?imgmax=800
            aha!
            is this right???
            http://www.xlr8yourmac.com/images/im...ply_pinout.gif
            • Kelly889
              • Sep 2010
              • 8
              Re: iMac G5 PSU
              Yes to all three questions.
              in the first pix - it looks like v 1.0
              Now looking at the third pix,
              pin 8 (PG) shows 5V
              pin 14 (ON/OFF) also shows 5V
              I probably have to ground one of them, most likely ON/OFF to get the PSU to power up. I just don't know which one.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Re: iMac G5 PSU
                short the on/off to ground i think
                • Quasar
                  • Sep 2010
                  • 132
                  Re: iMac G5 PSU
                  All that info is on this forum. Try using search.
                  • Kelly889
                    • Sep 2010
                    • 8
                    Re: iMac G5 PSU
                    Thanks Quasar,
                    I searched for iMac G5 PSU and didn't find what pins to do what with to power up the PSU without the computer.
                    Note: Looking more closely at the connector, I see that it's a 22 pin, not a 20 pin connector. So the pin numbers that I stated earlier are wrong. I'm using the picture in post #6 as my guide.
                    • Quasar
                      • Sep 2010
                      • 132
                      Re: iMac G5 PSU
                      I think I found what you need on page 3 of this thread. There are some 25 threads on iMac power supplies.
                      https://www.badcaps.net/forum/showthread.php?p=78821
                      • Kelly889
                        • Sep 2010
                        • 8
                        Re: iMac G5 PSU
                        WHAT A FIND!
                        Wow - that's exactly what I was looking for! I grounded pin 15 (ON/OFF) via a 56 ohm resister. (I don't like to ground them directly and 56 ohms is what I have hanging around.) I measured the voltages and they looked good open circuit. Put the PSU in the machine and it started right up.
                        Can't thank you enough.
                        btw: Looking at the second photo in post #6 of this thread, do you know what that silvery button is above the AC connector? I thought it might be a safety interconnect, but I don't think so because the PSU powered up fine outside of the computer.
                        • seanc
                          • Nov 2008
                          • 1319
                          Re: iMac G5 PSU
                          Cable lock slot
                          • Kelly889
                            • Sep 2010
                            • 8
                            Re: iMac G5 PSU
                            Yeah. I see that now. Thanks.
                            • godonr
                              • May 2009
                              • 111
                              Re: iMac G5 PSU
                              If you have AHT (AppleHardwareTest) DVD run it to verify video ram.
                              • marthyr
                                • Sep 2009
                                Re: iMac G5 PSU
                                • RossMoodley1967
                                  HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                  by RossMoodley1967
                                  Hello
                                  Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                  Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                  03-01-2024, 06:07 AM
                                • ktmmotocross
                                  iMAC 27" with PSU PA-2311-02A - not giving voltages
                                  by ktmmotocross
                                  Hello.
                                  Have this 27" iMac, that suddently after 2/3 yearsin storage wont start. when i connect power i was hearing some electric sparks sound from back of PSU. i wigle whole mac and it start with chore. so i remove PSU to check, but there is only AC input and output to board and see no bad connections. i resoldered big chips but nothing changed.
                                  when i measure it outside i found that only 1.3V on SDA/SCL pins. no PS_ON voltage or other voltages
                                  what can i measure to have better understanding where is problem?
                                  anybody know what voltages should be...
                                  08-18-2023, 10:35 AM
                                • Capacitorial
                                  Powersupply has all the voltages - Monitor still no power
                                  by Capacitorial
                                  Hello guys,
                                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                  The weird thing is, that the Power LED is powered over the TCON board.
                                  On The TCON...
                                  12-28-2024, 02:12 PM
                                • Crystaleyes
                                  iMac A1224 PSU, 614-0421 - no standby voltages
                                  by Crystaleyes
                                  Hi chaps.
                                  Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                                  I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                                  Anyway, this PSU in question had already had someone having a pop at soldering.
                                  The current problem is (at the very least) in the primary side.
                                  Fuse is ok
                                  MOV is ok
                                  NTC is ok
                                  Bridge rectifier is ok (~380vDC)
                                  Fat filter cap is ok
                                  10-11-2021, 05:07 PM
                                • ryogadan78
                                  iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                  by ryogadan78
                                  Hi guys, I need your help again.
                                  I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                  When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                  06-10-2025, 03:49 AM
