NKL Caps
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    NKL Caps
    Have anyone ever heard about a brand called "NKL" ?
    I've tried Google, but no luck
    See atached pic
  • japlytic
    • Oct 2005
    • 2086
    Re: NKL Caps
    Welcome, Rob!
    I have never seen this brand before.
    What is the manufacturer of this board with this brand of capacitor?
    • Rob Northen
      • Jan 2010
      • 137
      • Denmark
      Re: NKL Caps
      Thank you very much!
      The mfg. wont help very much, its Falck Securitas. A company making security systems in DK.
      Its a 4 Amp powersupply, 3 A for load and 1 for recharging 2x 42Ah accku's.
      They used this NKL brand, Panasonic and Vishay. I know the last two brands, very good.
      I haven't seen any PB's with several PSU's with this NKL brand. I'am just quite puzzeled with the name. I've bought some new Vishay BC Components ones to replace with.
      If anyone knows this brand, I'd be happy to hear about it.
      Edit:
      Reason for replacing, is i don't know the brand, but other caps on the board are Samsung and Cornell Dubilier CEBM series, and i've seen some of these fail, also using the cheap rubber "bong"
      • brethin
        • Dec 2008
        • 1907
        Re: NKL Caps
        NKL is based out of Germany.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: NKL Caps
          Have an actual company name or a link because all I can find [which isn't much] points to China.
          Mann-Made Global Warming.
          - Dr Seuss
          • Rob Northen
            • Jan 2010
            • 137
            • Denmark
            Re: NKL Caps
            Sounds like its a unknown brand to other than me.
            Brethin; If you have any company info or links, as pcbonez stated, that would be nice
            • c_hegge
              • Sep 2009
              • 5219
              Re: NKL Caps
              There are only 6 good brands vs about 100 bad ones, so when I see a brand I've never heard of, I always assume it's bad.
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
                by momaka
                03-12-2025, 03:42 PM
