ps4 supply no12v no 5vsb adp-160fr
  • totto210
    • Apr 2021
    • 51
    • chaco
    hi guys, I have a problem, the source recently had 4.8vsb but no acin_det
    CN121
    1_ acin_det 0v
    2_ acdc_stby 0,01v
    3_gnd
    4_5vsb 4.8v
    That was at first, I jumpered 2 and 4 and nothing happened.
    I tried to jumper 1 and 2 also, then I realized that I didn't have 4.8v anymore.
    1_ acin_det 0v
    2_ acdc_stby 0,01v
    3_gnd
    4_5vsb 1v
    a crazy thing
    on the main capacitors (c1 and c2) the big ones, I have 1v!
    and if I leave the gnd tester tip alone it measures an oscillating voltage between 0.03v and 0.05v !
    I don't know where to go from here.
    I don't know but I think mainly my problem was the ic151 not detecting the 5vsb.
    Then I turned the power supply back on and as I told you above I got 1v.
    I measured large capacitors c1 and c2 and they are well charged with the capacitance meter. there is no short.
    The diode bridge seems to be ok.
    thank you in advance. i leave a similar scheme.
  • CapLeaker
    Leaking Member
    • 8340
    Re: ps4 supply no12v no 5vsb adp-160fr
    If you got 1VDC on these big 450VDC caps, then you blew something on the input. Look at the fuse and any shorts, or other opens in the primary side of the PSU.
    • totto210
      • Apr 2021
      • 51
      • chaco
      hi capleaker,
      I already checked everything and I don't see anything strange, could the pfc integrated (ic41) be pulling this down? or the d11? What could I lift and see if I have voltage? If I get d11 could it explode? :S
        • 31247
        do you get ac and dc at the bridge rectifier?
        • totto210
          • Apr 2021
          • 51
          • chaco
          lol man , and thanks, the problem was the cable
          Well, problem one solved, now comes the second, which is the one I mainly had:
          I only have 4.8v in 5vsb, should I have in acin_det? Is it generated by ic151 itself?
          I make the short between pin 2 and 4 and nothing.
          • totto210
            • Apr 2021
            • 51
            • chaco
            Additional Information
            ic43
            pin1 0,38v oscilates to 0,3v etc
            pin2 0,2v
            pin3 4.3v
            pin4 0v
            changed ic43 and nothing
            r170 4.8v & 4.71v (ic151)
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
