Psu brands and series
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I want to make a one-stop list to list whther a psu brand is good or bad, or if the brand has some good series, etc.
    Starting here:
    Good:
    Corsair
    Seasonic
    Newer antecs
    Bad:
    Coolmax
    Raidmax
    Diablotek
    Antec smartpower 2.0 and truepower 2.0 (older)
    Linkworld
    Okia/broadway com corp
    Athena power
    Deer
    Leadman
    Powmax
    Zumax is questionable-i own 2 they feelsildmbut have fujyyu (fukyyu) caps
  • c_hegge
    • Sep 2009
    • 5219
    Re: Psu brands and series
    Add PC Power and cooling to the good brands list.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Problem is any company can make a terrible unit or a good unit. It all depends on how much you pay. Solytech makes the SL-8600EPS which is pretty widely used and performs well with good efficiency. They also make some huge pieces of crap. Same with CWT, AcBel, and even Delta (though they are REALLY good at getting the ripple right at spec at full load).
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Yes but for example in general a corsair is better than a diablotek
        I need a moderator to edit all the additions in. Because i cant edit the first post.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          >>I need a moderator to edit all the additions in. Because i cant edit the first post.<<
          They don't do that.
          It's not their job to edit everyone's private project.
          370forlife is right.
          If you don't go by specific models the list is pointless.
          You can get very good and complete crap from the same brand.
          Off the top of my head...
          Newer Antec are questionable. [Loaded with LTEC and some with OST.]
          The Basiq have OST - I think.
          Earthwatts vary. I've seen LTEC, Taicon, and OST. [Usually mixed with a few Jap Caps.]
          Older Antec with Smart, True, Blue, or Power in their name are Fuhjyyu Junk.
          Antec Neo [not w/HE] had OST and are junk.
          Some other Antecs are junk.
          Seasonic non-OEM models - okay
          Seasonic OEM models - OST - Junk
          HEC [aka Herolchi, aka Compucase] WinPower and AcePower models are good.
          Their Orion series is crap. [And ads don't always say it's an Orion.]
          Their OEM units are hit-miss.
          I haven't seen any of their newer 650 watt &up units.
          Enermax Liberty & Noisetaker PSU's had issues with glue becoming conductive with age causing dead shorts and sometimes flame-outs.
          Most other Enermax are okay [as far as I know.]
          Mann-Made Global Warming.
          - Dr Seuss
          • c_hegge
            • Sep 2009
            • 5219
            The only ones that consistently make good PSUs are Corsair and PC P&C. Even their cheaper models are pretty good.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              http://translate.google.com/translat...post1062880894
              They're ok. But it really depends on how much you pay them, as there are many models based on this same HEC design with out of spec ripple and even more meh voltage regulation.
              • larrymoencurly
                • Oct 2004
                • 960
                Originally posted by PCBONEZ;125051Newer Antec are questionable. [Loaded with LTEC and some with OST.
                Some other Antecs are junk..
                I've seen Ltecs in Delta-made PSUs, and I think many Antecs are now made by Delta, including current Basiqs. Older Basiqs, including the 500W model, had Capxons everywhere (room no problem for fatter replacements). Seasonic-made Antec EarthWatts and Trios had lots of OSTs. Antec SmartPower IIs were mostly Fuhjyyu, but the +5V standby supply could have Teapos or a Koshin, and the Koshins failed a lot more often on me.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  The Basiq series is built by FSP.
                  Delta does the some of the older and the newer Earthwatts and they use Taicon and LTEC.
                  The older non-Delta Earthwatts were Seasonic with OST.
                  - Dr Seuss
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    They're phasing out the basiq line and replacing it with another basic budget line from delta.
                    • cook
                      Good brands of run capacitor for house heat hump
                      by cook
                      Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                      Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                      09-13-2024, 12:53 PM
                      ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:28 PM
                      ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
