Power man ip-s300ff7-0 w'ont turn on
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Help me :
    I have power supply model (power man ip-s300ff7-0) w'ont turn on
    +5v power on(green yarn) voltage low 2.6v
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 221
    • Catalonia
    Re: Power man ip-s300ff7-0 w'ont turn on
    Hi:
    Only it has the 5Vsb? and is it low?
    In case both answers are affirmative I would start looking at capacitors. Specifically ¿C29? The one next to the IC.
    • aboumohamed
      • Dec 2018
      • 258
      • algeria
      Originally posted by Francesc V.
      Hi:
      thank you for the answer.
      +5vsb present
      the green wire 2.6v
      I replaced the c29 but the problem still persists I received 03 power supplies with the same problem
      • PeteS in CA
        • Aug 2005
        • 3578
        • USA, Unsure of Planet
        Does that P/S have an ATX-type output connector with ATX-style color-coding? If so, the green wire is the PSON# input signal. Pulling PSON# low is necessary to enable the main outputs.
        PeteS in CA
        • aboumohamed
          • Dec 2018
          • 258
          • algeria
          [QUOTE=PeteS in CA;1225105]Does that P/S have an ATX-type output connector with ATX-style color-coding? If so, the green wire is the PSON# input signal. Pulling PSON# low is necessary to enable the main outputs.
          This P/S has a 24pin ATX type output connector.
          but "ps-on" must have a voltage of 5v and not 2.6v
          • PeteS in CA
            • Aug 2005
            • 3578
            Repeating an important sentence from my post: Pulling PSON# low is necessary to enable the main outputs. If you haven't already, why not try grounding the PSON# pin and see what, if anything, happens? If, in the system, PSON# is pulled up by the motherboard, the voltage on that pin when the P/S is not connected to the motherboard will drift to ???, not necessarily 5V.
            PeteS in CA
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8670
              I have a powerman SFF ATX psu similar to this that croaked, replacing the caps in it brought it back to life... I even broke one of the fins off the fan by mistake and it's still running after many years of 24/7 service in my PVR.
              What I'm curious is it too is rated for some 300W IIRC, based on the size of the components and heatsinks, I'd be worried about pulling more than 150W or so from it...any comments about it?
              • aboumohamed
                • Dec 2018
                • 258
                • algeria
                I grounded the ps-on but no output voltage, the fan does not turn, I believe that the "ST9S313" ic is the cause of the failure
                • Francesc V.
                  Tempus fugit
                  • Nov 2022
                  • 221
                  • Catalonia
                  Well. This chip needs voltage.......and maybe is not receiving it.
                  I would say that issue is in capacitors........have you tested them? Put numbers on them......do a photo. Desolder them all and let's see.
                  Regards,
                  Francesc.
                  • CapLeaker
                    Leaking Member
                    • 7986
                    The main part of the power supply needs to turn on in order for the supervisor IC to get VCC. I would suggest looking on all the caps. Basically you got two power supplies in there. One is always on VSB (the one with a TNY2xx IC) and the other one is switched on and off. First you have to see that VSB is working correctly. Then you got to figure out how the supervisor works and may be even tricking it to force the PSU on. So, is the psu turning on for a split second and then the supervisor ic shutting back down or nothing happening at all? If you want you can read up on a Powerman ip that I repaired a while ago.
                    I think your st9s313 is the same as a WT7510 supervisor. Check carefully what the VCC and the FPL pin do.
                    • aboumohamed
                      • Dec 2018
                      • 258
                      • algeria
                      st9s313 voltage
                      pgo------0v pgi----------0v
                      vcc-------4.47v gnd
                      v5--------0v fpln----------4.79v
                      v33-------0v pdown-n 0v
                      • CapLeaker
                        Leaking Member
                        • 7986
                        Now follow the fpln through the secondary and it probably ends on an opto isolator. Right?
                        • aboumohamed
                          • Dec 2018
                          • 258
                          • algeria
                          Originally posted by capleaker
                          now follow the fpln through the secondary and it probably ends on an opto isolator. Right?
                          exactly i replaced the opto isolator which is on the right, the power supply turns 20 seconds then the failure returns again
                          • CapLeaker
                            Leaking Member
                            • 7986
                            See what the opto does. My bet is that when the PSU shuts down, you got something like 5v on one pin of the opto (secondary side) and at least 4v on the other pin, measured to secondary GND. Means the supervisor ic turned it off.
                            Could be a few reasons for this, like the main filter capacitors are bad, the output caps are bad on one or more voltage rails or the supervisor ic is bad.
                            If you put GND from the secondary to the fpln pin on the supervisor ic, you are going to defeat that protection and the PSU should stay on.
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • masoksian
                              Dell latitude e7470 not turn on .power buton on off and Run Power problem
                              by masoksian
                              I am dealing with the problem of turning on and off my Dell e7470 notebook.
                              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                              The system does not turn on, there is no post.
                              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                              The problem continues in the same way.
                              I tried to turn on the Fn key, nothing came to the screen....
                              02-15-2025, 12:08 PM
                              09-06-2024, 05:59 AM
                            • Journey11
                              Samsung TV won't turn on ... keeps cycling the power relay on & off
                              by Journey11
                              Hi All,
                              First time posting here ... my name is Kevin but my friends call me Journey.
                              I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                              After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                              It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                              07-04-2024, 02:44 PM
                            • meraklinetx
                              Asus Z97-a power cycle, no boot no cpu voltage
                              by meraklinetx
                              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                              05-10-2023, 06:08 AM
