"Achme" Power Supply from Shuttle SK41G
  • Jaw
    • Nov 2005
    After a recent post on slashdot about bad caps, I found my way here and started reading through everything I found. I have a VP-6 that could be at risk, but it seems okay. However, in more reading, it seems many Shuttles have problems too.
    I have an SK41G Shuttle XPC, and I figured it might be a good idea to take a look at it. The board looked fine, but the way the light I was using to check the caps hit the power supply grills, I noticed in the corner of my eye, a cap that didn't look quite right. On closer look, it had yellow stuff coming out of the top. I looked around a bit more and found another with the same condition. I haven't taken the PS apart yet, but I probably should.
    I guess I should recap it or replace it eh? Something told me to worry about this PS from day one because even when the unit is off it gets very hot.
    I'll try and get some pictures.
  • Jaw
    • Nov 2005
    Re: "Achme" Power Supply from Shuttle SK41G
    I could only get a picture of one of them...
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      looks bad. would be a good idea to recap it indeed. when you dissasemble it can we see some more pics.
      • Jaw
        • Nov 2005
        I've completed the "autopsy," and there were a total of 6 puffy caps, but only 2 were leaking electrolyte. The caps affected were black and silver branded capXon.
        I am not going to recap simply because its a tiny power supply; everything is really close together. I'm not skilled enough to work with electronics that have such close proximity. It looks like I'd have to remove a lot of stuff to get to the capacitors anyway. There are capacitors in the middle of the bundle of output wires.
        At some point I will replace the unit. For now I ghetto rigged a desktop PSU to the shuttle.
        • Rob
          • Oct 2005
          • 47
          How long did it take for those CapXons to fail... I don't think CapXon is a known trouble maker... Maybe a heat issue.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
