etasis 600w 1u Psu or mobo?
  • jguy
    • Mar 2023
    • United Kingdom
    Hi guys, basically i fired up a server rack i had by my mum for the last 2.5yrs unplugged. It has a etasis 600w 1u psu and dell t1600 motherboard. It went through all sorts of random reboots and power cycling for about 2 minutes thought something was fried but suddenly it worked fine and has been even after unplugging for hours now, thoughts?
    Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
    by sam_sam_sam
    Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
    I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
    09-13-2024, 06:47 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • Cerberuska
    Mobo MSI B550-A PRO password popup
    by Cerberuska
    Hello guys,
    I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
    BIOS I updated to last one.
    any suggestions?
    And same thing for two different 5600G, and yes, MoBo supposed to support it.
    Thank you...
    11-10-2024, 01:23 PM
  • mrsith
    Dell G3 17 3779 - no display after mobo replacement
    by mrsith
    Hi guys,
    I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
    Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
    04-30-2023, 05:11 AM
  • Ibod
    Corsair cx600 psu & ASRock B450Pro4 mobo wont start
    by Ibod
    HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
    With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
    Not sure where to go from here ?
    Is the PSU at fault or is the mobo causing the problem
    Look forward to any help :-)
    If I plug the 24...
    02-08-2023, 11:00 AM
