1000 whats!
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    #41
    Re: 1000 whats!
    Originally posted by 370forlife
    If you guys REALLY want to have a discussion about skimpy heatsinks, look at some of sirtec/High Power's and FSP's offerings. Even so, most of those units do just fine.
    About tiny heatsinks:
    650Watt
    400Watt
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: 1000 whats!
      See what I mean...
      Mann-Made Global Warming.
      - Dr Seuss
      • Rulycat
        • Apr 2010
        • 724
        #43
        Re: 1000 whats!
        I think it's hard to compare an old inefficient design with a more modern design. As it becomes more efficient it's natural they'll give it smaller heatsinks.
        • Pyr0Beast
          • Feb 2009
          • 406
          #44
          Re: 1000 whats!
          Modern design -> more savings on material )
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Re: 1000 whats!
            The ATNG in question shows about the same or better efficiency as the FSP GLN series. Both use two transistor forward.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #46
              Re: 1000 whats!
              The DR-8400BTX uses 2x13007 in a half bridge design.
              Usually they blow between 250-300Watt.
              • Trinite
                • Dec 2010
                • 143
                #47
                Re: 1000 whats!
                Originally posted by PCBONEZ
                See what I mean...
                I do now haha. When he starts refuting the validity of established mathematical principles, you have to wonder
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #48
                  Re: 1000 whats!
                  I'm sorry but PCBONEZ is right on this one. Half the current = half the voltage drop = half the heating. Period. Both simulations and real-world tests confirm this.
                  A working TV? How boring!
                  • lifthanger
                    • Dec 2010
                    • 10
                    #49
                    Re: 1000 whats!
                    Hi! This is my first post.
                    Really love this site and don't want to threadjack.
                    At the moment I don't fully understand this diode problem, so I'd like to write what I understand so far and maybe I could get some feedback.
                    Say for a 1n4001 at 25C which starts conducting at about 0.7V.
                    At 0.4A the drop of the diode would be 0.85V which would give a loss of: 1.4*0.95W= 0.34W
                    Two in parallel would get 0.2A each at 0.8V which would equal 2*0.2*0.8W = 0.32W.
                    60% could be possible with a diode with the right characteristics. Is that what this is about, or is my math wrong somewhere?
                    Thanks.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: 1000 whats!
                      The curve you are probably looking at is based on a constant Junction Temperature which isn't going to be true in a real circuit.
                      That curve defines design LIMITS [to prevent overheating the part].
                      - It is not stating operating CHARACTERISTICS as some are interpreting it.
                      The Junction Temperatures will go down which multiplies the reduction in heat dissipation to the point that two diodes in parallel need much less heat-sink than a single diode.
                      As I recall [from some thermal design discussion in an application guide or data sheet] they'll need 30-40% less heat-sink.
                      To correctly do the math you would need VxA curves for each Tj and most data sheets don't have that.
                      I did the research before after finding a data sheet with ALL the necessary curves and it's posted in another thread.
                      I don't currently have time [or the interest] to do it again.
                      - Dr Seuss
                      • lifthanger
                        • Dec 2010
                        • 10
                        #51
                        Re: 1000 whats!
                        yeah the curve was for a constant T. Actually this explanation is more than enough, thank you! This explains why I couldn't get much better dissipation with multisim. You can run 40A through a 1N4001 without a sweat in multisim. Obviously temperature is ignored there.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          #52
                          Re: 1000 whats!
                          You can do that with any simulation program. It's the designer's job to confirm that the parts he uses are adequate.
                          • Pyr0Beast
                            • Feb 2009
                            • 406
                            #53
                            Re: 1000 whats!
                            I NEVER refuted the validity of any mathematical principles. I merely questioned your methods of calculation and observation.
                            Yes. You have to wonder, and more importantly, ask yourself, If your methods of observation are correct. They are not, as I have pointed out before.
                            You are not sorry and are just as wrong as he is. Period.
                            Both simulations and real-world ? Are you bullshiting me ?!?
                            Show me parameters of simulation.
                            Show me real-world test data!
                            it is based on constant Junction temperature because that is the only way to compare data on two-dimensional chart.
                            Um what ?
                            That curve (forward voltage vs. current) does not even touch design limits. You have rectified current vs. ambient temperature derating curve for that.
                            No ? Then what it is stating ? Operating characteristics if such conditions are met.
                            Nah. Now you are just clutching at last straws and twisting the thread so it suits you better.
                            Are you telling me I should find the data to back up YOUR statements ? ....
                            Because multisim uses static diode data if you don't state otherwise.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Re: 1000 whats!
                              Can one of the mods please check if this guy's IP is the same as i4004 ?
                              Thanks.
                              - Dr Seuss
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                #55
                                Re: 1000 whats!
                                It is not. I can tell you that already.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Re: 1000 whats!
                                  WTF happened to everell's (and in a way, my) thread?
                                  i guess we all know where wwIII is starting... right here!
                                  could you two move the war elsewhere? my rig will not pull even close to 950w... closer to 400w max at current config. for now it is a moot point.
                                  sigpic
                                  (Insert witty quote here)
                                  • Pyr0Beast
                                    • Feb 2009
                                    • 406
                                    #57
                                    Re: 1000 whats!
                                    Hijacked
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: 1000 whats!
                                      The discussion is about how it can get away with small heat-sinks.
                                      Whether you like it or not that's on topic.
                                      - Dr Seuss
                                      • everell
                                        • Jan 2009
                                        • 1514
                                        Re: 1000 whats!
                                        Where is i4004??? I would like to hear his side of the argument!
                                        Thread hijacked??? I think this is a GREAT discussion on an important subject for high power power supplies.
                                        Is 950 watt power supply too much for a 400 watt computer. Perhaps there are other adverse effects. Heat may or may not be one of them.
                                        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                        • 370forlife
                                          Large Marge
                                          • Aug 2008
                                          • 3113
                                          Re: 1000 whats!
                                          Good luck pulling 400W from that computer. It will probably have a hard time hitting 250W.
