Here you go
Dell Inspiron 7559 board view & schematic Quanta AM9
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
DELL Vostro 3450 / Dell Inspiron 14R N4010 DAV02AMB8F1 Schematic & Board View...
Channel: Schematics and Boardviews
by jasonbay13it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
PU200
pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
pin 8 vreg3 = 0v
pin 13 en = .2v
pin 1,6 entrip1,2 = 0v
b+ and b++ = 19.5v
+5valw = 0v & 25+ohm to ground
+3valwp = 0v & 25+ohm to ground
i cleaned the board up just a little and can get more pics.
where should i be looking? thx... - Loading...
