i need the boardview of this board. thanks you
DELL N4110 V02A Boardview
Assuming...7 Photos -
by madan1Good day.
As mentioned in the title - I'm looking for boardview or board schematics for dell latitude 3310 2-in-1 with cpu I5 8th gen.
Thanks in advance.-
Channel: Schematic Requests ONLY!
04-02-2025, 03:38 PM -
by EpicFixKindly asking for schematics and boardview for:
Dell Inspiron 3530
Board IDH50 LA-M366P
Any help rendered greatly appreciated. Thanks in advance 😊....-
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by Garret Matt.Hello,
I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
Thank you in advance for any assistance you can render.
Inductor In question. Buzzes like...-
06-20-2025, 01:21 PM -
- Loading...
