I need Board Schematics and Boardview of LA-J491P for my Dell G7 17 7700. Does anyone have it?
  • Ruhi
    • Sep 2025
    • India
    I need Board Schematics and Boardview of LA-J491P for my Dell G7 17 7700. Please share the file if anyone has it
    Thanks in advance.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • Garret Matt.
    DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
    by Garret Matt.
    I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
    Thank you in advance for any assistance you can render.
    Inductor In question. Buzzes like...
    06-20-2025, 01:21 PM
