Hp elitebook 840 g3 battery not charging
  • karim011
    • Nov 2016
    • 122
    • Morocco
    Hi everyone. Pls i need schematic or boardview for hp elitebook 840 g3 mainboard i.d : 6050a2892401-mb- a01
    problem battery present but not charging. I tried to replacing 3 batteries and chargers but without result. Pls you help.
  • mon2
    • 14660
    Re: Hp elitebook 840 g3 battery not charging
    Hi. You have posted in the wrong section. Post the details in the laptop repair forum.
    Schematic is often not required but of course will help.
    Locate the charger IC and post pics or at least the markings from the topside of the IC.
    Guessing it will be the TI 'BQ' series.
    • karim011
      • Nov 2016
      • 122
      • Morocco
      Thank u sir
      • piernov
        Laptop battery charging circuit
        by piernov
        1. Some theory
        1.1. Introduction
        Almost every laptop has a charging circuit of some sort, that does a few things:
        • Manages switching between AC adapter and battery power
        • Manages battery charging and generates power rail to charge battery
        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
        • Narrow VDC (NVDC)
        Texas instrument has a nice overview of these technologies with some more details at https:...
        11-15-2020, 01:31 PM
      • kodox
        ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
        by kodox
        since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
        the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
        what i've done:
        - flashing...
        12-29-2024, 02:49 AM
        12-31-2023, 06:04 AM
      • Shinju
        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
        by Shinju
        Hey All!
        Long time forum member here with a problematic laptop issue!
        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
        The laptop would not power on with the new battery installed without the power supply being plugged in.
        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
        10-20-2021, 04:58 PM
      • Iherduleikgemz
        Asus FX505DY - Battery not charging - BQ24780S
        by Iherduleikgemz
        Hello everyone
        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
        01-13-2025, 03:54 PM
