Hi Everyone, im currently troubleshooting Dell E5250 laptop with charger detection issue, which shows "unable to determined charger wattage" during bios post state, can't do any further progress due to not having the schematic, hopefully anyone here could help me out, Thank you
In Need for LA-A891P Dell E5250 schematic
Re: In Need for LA-A891P Dell E5250 schematic
hi everyone, im currently troubleshooting dell e5250 laptop with charger detection issue, which shows "unable to determined charger wattage" during bios post state, can't do any further progress due to not having the schematic, hopefully anyone here could help me out, thank you
by BTubbs200Hello,
Dell Latitude 5420 P137G
Board: LA-K491P REV A01
I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
Board seems to have no shorts, all power rails are fine and show high resistance.
When charger is plugged in, voltage is present in 3.3V rail but absent in others.... -
by JohndillHi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
Here are the tested scenarios:
1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
2. With the laptop off, plug in charger (LED says on) & the front charging... -
I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
Any common faults that could be fixed?
I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
How does the communication between the charger and the PC work?... -
by exerion5000Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
below normal, as if it were operating in an extreme energy... -
DELL Vostro 3450 / Dell Inspiron 14R N4010 DAV02AMB8F1 Schematic & Board View...
Channel: Schematics and Boardviews
- Loading...
