Please any can helpme, device no power, no led when charger connected.
Need BoardViewer HP 11-2010nr (da0c1mbaaf0)
Re: Need BoardViewer HP 11-2010nr (da0c1mbaaf0)
You gave us Shakira so certainly we can (try to) help.
Post the request as a new thread in the laptop repair forum.
Unable to locate a boardview file for this logic board but it may not matter. Do you have soldering tools + multimeter ? Logic board is available to take some measurements ?
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
by JohndillHi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
Here are the tested scenarios:
1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
2. With the laptop off, plug in charger (LED says on) & the front charging... -
ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
Highly Integrated Narrow VDC Battery Charger for Notebook Computers
The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
Narrow VDC applications where the system power source is
either the battery pack or the regulated output of the charger.
This makes the max voltage to the system equal to the max
battery voltage instead of the max adapter voltage. Operating
at lower system voltage can improve...-
11-05-2024, 04:43 PM -
- Loading...
