Asus x412fl rev 2.0 boardview
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    Need help , just power led on
  • Sarwar sahi
    • Jan 2022
    • India
    Re: Asus x412fl rev 2.0 boardview
    I need X412FLC REV 2.0
    • Ismael Shah
      • Jul 2021
      • 8
      • india
      i need X412FLC R2.1 BOARDVIEW
      • dharmvir
        • May 2016
        • 4
        • india
        • mrmouse17
          • Oct 2021
          • 33
          • viet nam
          thank you
          • gustarom
            • May 2013
            • 44
            • indonesia
            thanka alot
            • BeOneIT
              • Aug 2023
              • 6
              Thank You.
              • Blackout76
                • Nov 2023
                • Italia
                Forgive me, I need the schematic
                • joen_d66
                  • Apr 2013
                  • 68
                  • jakarta
                  Thanks bro
                  • gmacz
                    • Jun 2018
                    • 40
                    • Sri Lanka
                    Thank you Sir
                    • chuottuan
                      • May 2014
                      • 4
                      • Viet Nam
                      thanks you, Forgive me, I need a repair Guide
                      • ibon9527
                        • Nov 2024
                        • taiwan
                        thank you bro! love u
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • meraklinetx
                          Asus Z97-a power cycle, no boot no cpu voltage
                          by meraklinetx
                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                          05-10-2023, 06:08 AM
                        • Duranitron
                          Asus x512dk rev 2.1 power on problem
                          by Duranitron
                          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                          11-26-2024, 10:22 PM
                        • Thomas Smith
                          Asus Tuf gaming fx506l no power, mosfet does not open
                          by Thomas Smith
                          Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                          Initial Symptoms:
                          • The laptop has no power at all (no LEDs, no fan spin).
                          • No 3.3V or 5V present on the board.
                          • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                          Power Rail Checks:
                          1. Charger input (FETs PKCH2BB)
                            • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                          2. BQ24780S Charger IC:
                            • VCC and ACDET are present.
                            • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                            • Shunt resistor has 10Ω to ground.
                          03-30-2025, 03:38 AM
