Hello my friends please help. DA0U33MB6E1. REV E
  • mohammed mohan
    • Nov 2017
    • 201
    • z
    I have a motherboard that had a problem when I wanted to replace a damaged piece and the paintings were damaged by mistake. Does anyone of you have a clear close-up picture of this place shown in the attached pictures?
    Board number DA0U33MB6E1. REV E
    Thank you all
    Mohammed Mohan
  • mohammed mohan
    • Nov 2017
    • 201
    • z
    Re: Hello my friends please help. DA0U33MB6E1. REV E
    Mohammed Mohan
      • 22030
      The layout is the same in the DA0U33MB6D0 schematic.The parts locations are marked on the board. You can test the capacitance of the dislodged caps but not the voltage !
      • mohammed mohan
        • Nov 2017
        • 201
        • z
        thank you my friend
        Mohammed Mohan
        • XxMicroSoldering
          ASUS Rog Strix G17-712LV Laptop Liquid damaged
          by XxMicroSoldering
          Hello Guys
          I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
          10-17-2024, 10:45 AM
        • Tomylee
          Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
          by Tomylee
          I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
          It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
          I'm looking for help with the following:
          The exact identification or part number of the T5 component
          05-28-2025, 12:42 PM
        • tofik
          LG 50PA6500 Plasma TV damaged after a power spike
          by tofik
          Hello, I have an LG 50PA6500 Plasma TV, purchased new in 2012.
          Unfortunately plasma is not working at all after a power spike.
          Qucikly tested the PSU and voltages seems to be okay, when eveything is disconntected from the PSU I got:
          VS = 200-206 / actual = 205 V,
          VA = 55 / actual = 54.9 V,
          M5V = 5.2 / actual = 5.19 V,
          17 = 17.24 V,
          5.2 = 5.19 V,
          STDBY = 5.19 V,
          ERROR_DET = 4.8 V - does it mean PSU is damaged? the rest of the voltages seems to be fine.
          what's your opinion about the PSU?
          Also I just...
          12-20-2022, 03:08 PM
        • Qhuy
          Razer RZ09-O328, Values For The Damaged Capacitor?
          by Qhuy
          Anyone knows the value for the damaged capacitor for the Razer RZ09-0328, Board number is DA550-mb. Please see pictures. Thanks in advance.
          11-05-2025, 09:48 PM
        • phantomEVO
          [help]820-01521 WATER DAMAGED
          by phantomEVO
          HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
          https://files.fm/f/6gjpqyjw3q
          here some measurements
          ppbus_g3h 12,29v
          PP3V3_G3H 3,29v
          pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
          PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
          PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
          PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
          with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
          10-24-2025, 04:23 AM
