Motherboard scheme Lenovo G710 (20252)
  • Cossgl
    • Jan 2022
    Hi friends, I have a Lenovo G710 that doesn't want to boot. I tried to repair the power connector (it was broken and no longer had perfect contact) and after I fixed the problem and assembled the computer it did not start. Only the power LED lights up. The screen is closed, the supply voltage to the connector on the motherboard is 18.8v, in pin 3 it is 1.4v, there are no components that overheat. It's been a few days since I've been looking at it for a long time and I don't understand what got it, it worked perfectly. Am I doing something wrong with the commissioning? What do you say, how can I solve this problem. I think a scheme might be helpful, but I only found it in .bin format. Can you help me with a .pdf file or how to open this .bin file. Thanks.
    • 22191
    Re: Motherboard scheme Lenovo G710 (20252)
    Pegatron DUMBO2 schematic not available .The *.bin you found is most likely a bios dump.
    • Cossgl
      • Jan 2022
      And yet, what schemes do you use. Colleagues on this forum exchange information and solve problems appeared at Lenovo G710 based on a hardware scheme, are posts with captures of this scheme, even on youtube are tutorials the same. So can you help me?
      • andrhouseolly
        Lenovo X240 - motherboard replacement for X250, no image.
        by andrhouseolly
        Friends. I beg you to help me in this situation.
        Lenovo X240 with a video problem. Native Intel drivers are not installed,
        after installation, a black screen. It works with the standard Microsoft driver.
        Understanding that there are problems with the video core,
        I ordered a motherboard from Lenovo X250.
        The laptop turns on, starts up, there is no image on the internal display.
        The image is output to the external monitor.
        I ordered another motherboard from Lenovo X250.
        07-12-2024, 03:02 PM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • rddube
        Need help interpreting schematic of Lenovo B470 motherboard
        by rddube
        OK, so here is my issue.
        This Lenovo B470 motherboard I am troubleshooting died and I identified it is the discrete Nvidia graphics chip that has lost it's ways!
        So I removed it and now I am trying to change this motherboard to use UMA graphics, but I am having an issue interpreting the attached diagram. I have a 10K resistor in at the R2013 position and another one at the R2012. R2010 and R2011 are empty.
        The motherboard starts, the fan spins but no display. It turns off by itself. I restart it and it does start but stays on...
        08-12-2024, 02:01 PM
      • Giggle2562
        Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
        by Giggle2562
        I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
        The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
        Here's what I've tried so far:
        • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
        • The laptop shows an image on the internal display for a few seconds before it shuts down.
        • I tried swapping the LCD panel with a known good one.
        • I tried swapping the LCD cable
        11-06-2025, 12:36 PM
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
