WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
  • inflex
    • Aug 2012
    • 544
    Re: WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
    Removing the password is trivial.
    I took a file which has a password in it, and removed the string that occurs after the .G34S string and set the string length byte to 0. Now is readable in TeboView 4 without requesting the password.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • mmu
      • Aug 2019
      • 28
      • France
      #62
      Oddly the Gigabyte file didn't open in TeboView 4 even after stripping the password… But forcing the previous string to "G34…" stopped it from complaining about license :-)
      Opened a PR with a python tool to strip the password.
      • inflex
        • Aug 2012
        • 544
        Anyone want to throw a theory on why some of the TVW files have this extended sort of header before the first labelled layer?
        Seems there's a few occurrences of the 0 3 2 1 sequence in it.
        This is the Gigabyte file that was attached in a slightly earlier post here in this thread.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1213
          • France
          #64
          For decoding Customer ID
          0000000 1111111 2222222 3333333 4444444 5555555 6666666 7777777 8888888 9999999
          efgefge fghfghf ghighig hijhijh ijaijai jabjabj abcabca bcdbcdb cdecdec defdefd
          aaaaaaa bbbbbbb ccccccc ddddddd eeeeeee fffffff ggggggg hhhhhhh
          3453453 2342342 1231231 0120120 9019019 8908908 7897897 6786786
          iiiiiii jjjjjjj kkkkkkk lllllll mmmmmmm nnnnnnn ooooooo ppppppp
          5675675 4564564 vutsrqp wvutsrq xwvutsr yxwvuts zyxwvut kzyxwyu
          qqqqqqq rrrrrrr sssssss ttttttt uuuuuuu vvvvvvv wwwwwww xxxxxxx
          ikzyxwv mlkzyxw nmlkzyx onmlkzy ponmikz qponmlk rqponml srqponm
          yyyyyyy zzzzzzz
          tsrqpon utsrqpo
          First Number
          0 e
          1 f
          2 g
          3 h
          4 i
          5 j
          6 a
          7 b
          8 c
          9 d
          a 3
          b 2
          c 1
          d 0
          e 9
          f 8
          g 7
          h 6
          i 5
          j 4
          k v
          l w
          m x
          n y
          o z
          p k
          q l
          r m
          s n
          t o
          u p
          v q
          w r
          x s
          y t
          z u
          75785zn
          badcaps
          • inflex
            • Aug 2012
            • 544
            Oh my, how did you conjure this up? Inside knowledge or just worked out the crypt?
            Regards, Paul.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1213
              • France
              #66
              Regards, Paul.
              I never use teboview
              just search and compare
                • 20504
                It does appear in boardviewer
                • inflex
                  • Aug 2012
                  • 544
                  You chaps are vastly better at this than I am. Thank you.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1213
                    • France
                    #69
                    Regards, Paul.
                    license must match in the program to open the file. otherwise failure
                    The license can be modified in IctViewLicense.dll
                    • inflex
                      • Aug 2012
                      • 544
                      So their licence "name" is locked at 7 chars (max) ?
                      At least with the decoder we won't need to worry about that, but at least it's nice to know what that field is for.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1213
                        • France
                        #71
                        no idea for 7 chars,I just tested like this
                        • mmu
                          • Aug 2019
                          • 28
                          • France
                          #72
                          Hmm so possibly other strings are encoded alike ?
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1213
                            • France
                            #73
                            if I have time I will try to make an excel table as usual to decode
                            • inflex
                              • Aug 2012
                              • 544
                              Was thinking the same, like the other headers. Just off to sleep again, but worth trying on those other strings in the header.
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1213
                                • France
                                #75
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1213
                                  • France
                                  #76
                                  First byte 07 is sum of chars .
                                  07 47 33 34 76 53 34 7A 00 11 59
                                  _________ HEX ____________ASCII ____ DECODE______
                                  07 47 33 34 76 53 34 7A = G34vS4z = LianBao
                                  possible to modify the number of characters but you have to remove unnecessary letters from the dump, just leave 00 at the end.
                                  03 48 6E 49 00 11 59
                                  EX: 03 48 6E 49 = HnI = MxP
                                  8 chars max
                                  blocked by exe, not succeeded in putting more
                                  Many teboview (v3/v4.11/v4.12) with other customer ID in attachements
                                  • inflex
                                    • Aug 2012
                                    • 544
                                    Added a string decoder for testing, and will add this to the main program later.
                                    https://raw.githubusercontent.com/in...ode-string.cpp
                                    Code:
                                    pld@WorkstationTT:~/development/pld/teboviewformat$ gcc -Wall decode-string.cpp -o decode-string
                                    pld@WorkstationTT:~/development/pld/teboviewformat$ ./decode-string 75785zn
                                    badcaps
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1213
                                      • France
                                      #78
                                      8th chars
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1213
                                        • France
                                        #79
                                        (the 3-2-1 sequence appears to be a header/lead-in as opposed to a suffix).
                                        indicates the start of each chapter or page, the last byte change, I don't know how to explain
                                        exemple:
                                        03 00 00 00 02 00 00 00 01 00 00 00 0E SILKSCREEN_TOP
                                        03 00 00 00 02 00 00 00 01 00 00 00 0E SOLDERMASK
                                        03 00 00 00 02 00 00 00 01 00 00 00 03 TOP
                                        03 00 00 00 02 00 00 00 01 00 00 00 03 IN1
                                        • inflex
                                          • Aug 2012
                                          • 544
                                          exemple:
                                          The last byte is the string-length of the layer name.
                                          • testaccgta
                                            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                            by testaccgta
                                            Hi, everyone!
                                            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                            09-01-2024, 08:24 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Zentech
                                            Unable to Write Bios File to SOCIC 25Q128FVPQ Chip
                                            by Zentech
                                            bios chip: 25Q128FVPQ
                                            MB SN: 6050A2822301-MB-A01
                                            when I first got this laptop the bios was locked, I unsoldered and unlocked the bios. the problem is that I lifted a couple of pads from the MB. So I couldn't use the WSON chip that comes with the board, so I got an equivalent bios chip SOCIC 8pin. The problem is that I'm trying to write the file (original) to the chip and it will not program it. I'm using NeoProgrammer.
                                            Here's the error
                                            Code:
                                            Current programmer: CH341
                                            15:29:00
                                            Programming memory(verifying)...
                                            Verification error on address: 00133000
                                            03-10-2022, 02:39 PM
                                          • hazem3636
                                            need Bios Bin file Dell server 220
                                            by hazem3636
                                            hi everyone
                                            i need dump file for dell server r220
                                            i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                            i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                            if anyone has this method please need his supporting .
                                            all the best
                                            EXE file is attched and Original Bin file from the Bios Chip is attached also
                                            and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                            11-05-2022, 06:20 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
