WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
  • mmu
    • Aug 2019
    • 28
    • France
    Re: WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
    The Query button actually helps a lot in TeboView.
    Still not sure how the data is layed out in the layer sections, I'm still missing something.
    • inflex
      • Aug 2012
      • 544
      Originally posted by mmu
      Thanks, this one runs, but doesn't help much.
      The decompiled version doesn't have much info, just tons of hex :-)
      The developer is quite stringent with his cleaning up of the binary to make sure there's nothing easy there for you to use. I should be more like that
      YouTube Repair Videos - https://www.youtube.com/user/19PLD73
      FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
      • inflex
        • Aug 2012
        • 544
        Are you able to reliably jump to the end of the layers down to the start of the network names yet?
        I'm hoping that the ID->NetworkName translation data isn't in the layers, that would be a pain.
        Any idea what all the "Breakwater" and "Sensor" information might be after the network names and before the part definitions?
        EDIT: Thanks for mentioning the "query" facility, for some reason I didn't initially seem to have that tab/window showing up when I clicked on things with the query, but after resetting the program it now shows, so that's great, a good bit of information there to be gathered!
        • inflex
          • Aug 2012
          • 544
          Network names in the system appear to be 0-based indexed items. If you click on the various pads/areas the network name has the index in brackets after ie, gnd(0)
          • inflex
            • Aug 2012
            • 544
            Part header fields for "height", "part type" determined, the UID string I wasn't sure about appears to be an internally generated "serial" string as well.
            • inflex
              • Aug 2012
              • 544
              Found all the part types that are internal to TeboView
              Code:
              PART TYPE field
              value	 | description
              0		 IC
              1		 DIODE
              2		 TRANSISTOR
              3		 RESISTOR
              4		 RESISTOR NETWORK(SI)
              5		 CAPACITOR
              6		 CAPACITOR NETWORK(SI)
              7		 ZENER
              8		 LED
              9		 JUMPER
              10		 BATTERY
              11		 MASK
              12		 RELAY
              13		 FUSE
              14		 CHOKE
              15		 CRYSTAL
              16		 SWITCH
              17		 CONNECTOR
              18		 TEST POINT
              19		 TRANSFORMER
              20		 POTENTIOMETER
              21		 MECHANICAL
              22		 RESISTOR NETWORK(DI)
              23		 RESISTOR NETWORK(SB)
              24		 RESISTOR NETWORK(DB)
              25		 CAPACITOR NETWORK(DI)
              26		 CAPACITOR NETWORK(SB)
              27		 CAPACITOR NETWORK(DB)
              28		 STRAP
              29		 FUDICIAL
              30		 UNKNOWN / END
              • inflex
                • Aug 2012
                • 544
                Bit of an important breakthrough here.... the UINT32 I thought was the network number, I suspect it's actually a PAD INDEX, so the pad array is instead where we'll find the network name.
                I was tweaking values in the pin-index sequence of a part and noticed when I changed the UINT32 value to other existing values, the numerical index of that pin would appear in the respective pad.
                See the image attached.
                So in a way we've found that there is indeed an intermediate/translation table but it's a "PAD" array, and in there we'll find hopefully our network ID... now just to find that array :|
                NOTE/EDIT: Changing the value only changes the position for the display of the string, it's not changing the network or other details of the pad, so the index is just to point to the pad structure where to put the string, as opposed to changing which pad is *associated* with the pad.... so there may be yet another table.
                • mmu
                  • Aug 2019
                  • 28
                  • France
                  #28
                  Ah cool.
                  Last night I managed to parse the first layer of NSB241R10.tvw until the next one.
                  Still not sure what the first int after the colors are, but after the D-code definitions (ended abruptly with 0,1 as w,h) are listed the pads, lines, surfaces… with a count and the content if count isn't 0.
                  • inflex
                    • Aug 2012
                    • 544
                    Ah cool.
                    Very much looking forward to seeing what you have to show when done.
                    • mmu
                      • Aug 2019
                      • 28
                      • France
                      #30
                      Ok the pads in the TOP layer have a different length for the structure, seems there are extensions to it for punching the hole.
                      • inflex
                        • Aug 2012
                        • 544
                        I'll wait for you to draw up a rough format spec and then I'll dig in with that.
                        I noticed there's a lot of repeated structures on most layers that look suspiciously like the tables I'm after ( see image )
                        Are you decoding stuff like that?
                        • mmu
                          • Aug 2019
                          • 28
                          • France
                          #32
                          Yeah that's a list of pad/lines/whatever, with the number of entries, some unknown uint32, then the net, the d-code id (starts at 10), then coordinates…
                          I'll start writing that up, but I must post the retrocomputing devroom request for FOSDEM first before tomorrow :-)
                          • inflex
                            • Aug 2012
                            • 544
                            Any chance you can quickly just do a screen shot showing me a hex pad-block with the uint32, net, d-code ID, coordinate sequence?
                            • inflex
                              • Aug 2012
                              • 544
                              Okay, I worked it out, used the cooordinates to give me the anchor point for what you were talking about...and yes, now I see the network ID... HUZZAAARH!!!
                              • dzaima
                                • Nov 2021
                                • Latvia
                                #35
                                Here's a big file of things I've decoded so far in the cds2f_NSA912R10-0329.tvw file: https://gist.github.com/dzaima/b07e8...eea748b8c60ea2
                                Absolutely no clue what boards are or what the file represents, hence the very unhelpful names for everything, but decoding parts of a binary format seemed like a fun programming challenge.
                                Pretty much everything there is parsed starting from a hard-coded location in the file (in the log printed after "@"s, in decimal) as I don't know how the layer formats work, but maybe this can serve as a hint on what to do when encountering things for the people here who actually know what they're doing, and I've tried to lay out the structure of the various things I parse at the start of the file too.
                                • dzaima
                                  • Nov 2021
                                  • Latvia
                                  #36
                                  For example, at line 591 is the decoded values of the selected bytes in inflex's last message. The format that's in is described in lines 23-40.
                                  • inflex
                                    • Aug 2012
                                    • 544
                                    From here I can start to write up the first crude importer for OBV/FlexBV.
                                    Many thanks @MMU, that was the hint that bought it all together.
                                    • inflex
                                      • Aug 2012
                                      • 544
                                      I forgot to mention, basically if you take the PIN PAD array ID, bitshift by 3 (divide by 8) it should give you the 0-based index of the PAD array in the layer it's present in/on.
                                      ie, Pin 3 of JODD3 has a pad index code of 0x48, >>3 and we get 0x09.
                                      if we then look at the TOP layer pad/item array, we see the 10th item ( remember, 0-indexed) it's the right coordinates and show's a network index of '2', which is correct according to the TBViewer suite info panel for JODD3:3
                                      So that essentially all ties it up.
                                      Now I have to go and write a parser that'll correctly read the file structure based on what we know.
                                      • mmu
                                        • Aug 2019
                                        • 28
                                        • France
                                        #39
                                        Ok great.
                                        I just pushed whatever I did last night to my branch.
                                        Attached is what I decoded of NSB241R10.tvw with it.
                                        • mmu
                                          • Aug 2019
                                          • 28
                                          • France
                                          #40
                                          I still have an issue parsing the Surface list though, on some files there's an extra value after the first entry which isn't there on other files, and I can't find how it's decided.
                                          • testaccgta
                                            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                            by testaccgta
                                            Hi, everyone!
                                            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                            09-01-2024, 08:24 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Zentech
                                            Unable to Write Bios File to SOCIC 25Q128FVPQ Chip
                                            by Zentech
                                            bios chip: 25Q128FVPQ
                                            MB SN: 6050A2822301-MB-A01
                                            when I first got this laptop the bios was locked, I unsoldered and unlocked the bios. the problem is that I lifted a couple of pads from the MB. So I couldn't use the WSON chip that comes with the board, so I got an equivalent bios chip SOCIC 8pin. The problem is that I'm trying to write the file (original) to the chip and it will not program it. I'm using NeoProgrammer.
                                            Here's the error
                                            Code:
                                            Current programmer: CH341
                                            15:29:00
                                            Programming memory(verifying)...
                                            Verification error on address: 00133000
                                            03-10-2022, 02:39 PM
                                          • hazem3636
                                            need Bios Bin file Dell server 220
                                            by hazem3636
                                            hi everyone
                                            i need dump file for dell server r220
                                            i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                            i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                            if anyone has this method please need his supporting .
                                            all the best
                                            EXE file is attched and Original Bin file from the Bios Chip is attached also
                                            and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                            11-05-2022, 06:20 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
