hi anybody can guess this chip is for ? no schematic no boardview ,couldt find on previous model
Macbook pro M1 A2338 820-02020 schematics boardview
Here are the schematics and location view of major components
Still looking for the boardview file or silkscreenComment
Re: Macbook pro M1 A2338 820-02020 schematics boardview
Finally finished the task of creating the board view file and cleaning the schematic pdf
So if you find any error please reply here and will see if a can and/or want to correct them. ( 1 SIDE NOTE the ic UP102 and components are not on the actual board but are there to connect the signals)
So enjoy the hard work.Attached FilesComment
I would love some of the back story to how you conjured this up ?
My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SAComment
THANKS a lot !
So enjoy the hard work.Comment
BTW is there out some tutorial for create this kind of boardviews? i have xinzhizao vip and i wish to learn.Comment
truely impressedComment
@whizkidz absolutely remarkable work! When I’m next in Amsterdam I owe you many beersComment
Apple MacBook Pro M1 A2338 820-02020-A Boardview...
Channel: Schematics and Boardviews
by CG_DionysosHello,
I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
Thanks in advance!
Greetings from Germany...-
Channel: Schematic Requests ONLY!
09-16-2025, 06:43 AM -
by OruxHi all,
I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...6 Photos -
by sdogsGreetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was... -
I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was... - Loading...
