Macbook pro M1 A2338 820-02020 schematics boardview
  • charles75328
    • May 2024
    Thank youuuu very much!
    • zippylin
      • Nov 2020
      • 15
      • us
      #122
      thank you
      • Jcbasi
        • Apr 2024
        • Spain
        #123
        Thankssssss
        • jesi
          • Jul 2013
          • 78
          • uk
          #124
          thankyou
          • Siddig
            • Jun 2017
            • 264
            • Sudan
            #125
            Originally posted by whizkidz
            Re: Macbook pro M1 A2338 820-02020 schematics boardview
            Finally finished the task of creating the board view file and cleaning the schematic pdf
            So if you find any error please reply here and will see if a can and/or want to correct them. ( 1 SIDE NOTE the ic UP102 and components are not on the actual board but are there to connect the signals)
            So enjoy the hard work.
            thank you so much
            • Saratoga MicroSoldering
              • Oct 2021
              • 7
              Thank You!
              • casablanca
                • Aug 2016
                • 7
                • South Africa
                #127
                THANK YOU
                • rsjp2
                  • Nov 2016
                  • France
                  #128
                  Thank you very much
                  • astyrcz
                    • Dec 2021
                    • The Netherlands
                    #129
                    Thanks whizkidz
                    • dreamflowers09
                      • Feb 2012
                      • 31
                      #130
                      thank you very much friends
                      • casablanca
                        • Aug 2016
                        • 7
                        • South Africa
                        #131
                        thank you so much friend
                        • franzb1
                          • Jul 2015
                          • deutschland
                          #132
                          thank you
                          • condensadorentrolitico
                            • Jan 2019
                            • 10
                            • corralejo
                            #133
                            thanks
                            • ntsif
                              • Mar 2025
                              Thanks to you whizkidz and DerekChen65535
                              • Sergio Kub
                                • Jul 2018
                                • 176
                                • Brasil
                                #135
                                Thank You.
                                • phil0072
                                  • Oct 2020
                                  • FRANCe
                                  #136
                                  I have fixed the issue above in BVR.
                                  Many thank for this great work
                                    Apple MacBook Pro M1 A2338 820-02020-A Boardview
                                    Apple MacBook Pro M1 A2338 820-02020-A Boardview...
                                    10-22-2024, 02:25 AM
                                  • CG_Dionysos
                                    MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                    by CG_Dionysos
                                    I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                    • Model: A1707
                                    • 15-inch, Mid 2017
                                    • 3.1 GHz Core i7
                                    • 16 GB RAM
                                    • Radeon Pro 560
                                    • 1 TB SSD
                                    • Board number: 820-00928-A
                                    I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                    Thanks in advance!
                                    Greetings from Germany...
                                    09-16-2025, 06:43 AM
                                  • Orux
                                    Macbook Pro M1 A2338 13"
                                    by Orux
                                    I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
                                    I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
                                    One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
                                    09-22-2025, 12:54 PM
                                  • sdogs
                                    macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                                    by sdogs
                                    Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                                    First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                                    I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                                    06-27-2025, 01:58 PM
                                  • sdogs
                                    by sdogs
                                    06-27-2025, 11:26 AM
