msi ms-16w11 ver:1.1 need schematic
  • raizenn27
    • Jun 2011
    • 95
    • philippines
    ms-16w11 ver:1.1 schematic needed.,pls someone thanks in advance
  • karemkf
    • May 2020
    • 22
    • egypt
    Re: msi ms-16w11 ver:1.1 need schematic
    good lack
    • kukasIII
      • Aug 2012
      • 11
      • lisboa
      thanks for the share Karemkf
      • alaaljumaily
        • Jan 2022
        • 19
        • IRAQ
        thanks YOU brother
        • Dixon76
          • May 2019
          • Paraguay
          Thanks YOUUUUU
          • Zilicon
            • Nov 2020
            • 142
            • Nigeria
            MS-16W11 VER: 1.0 schematics and boardview request
            Hi fellas,
            Please help with the above boardview and the schematics.
            • mdaa2003
              • Jan 2015
              • cairo
              thank you karemkf
              • Crazielaptops
                • Jan 2024
                Nice..
                • hpboy
                  • Jan 2021
                  • 53
                  Thank you
                  • lazikkk
                    • Aug 2022
                    • Russia
                    Thank you!!!😊
                    • bion
                      • Oct 2015
                      • 5
                      • JAKARTA
                      good lack
                      thank you
                      • Vuqar
                        • May 2017
                        • 11
                        • Pashayev Vuqar
                        Thanks bro
                        • Dimon_Kh
                          • Jul 2023
                          • Ukraina
                          good lack
                          thanks for the share)
                          • walidovic
                            • Sep 2024
                            • Algérie
                            thank you
                            • luisfm2
                              • Jan 2015
                              • 51
                              • Portugal
                              Thank you.
                              • ruslan657
                                • Mar 2016
                                • 69
                                • Azerbaijan
                                thanks
                                • MicroSMD Lab
                                  • Sep 2018
                                  • 145
                                  • Trinidad and Tobago
                                  • TinkerTron
                                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                    by TinkerTron
                                    Hey everyone,
                                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                    Instead, here's what's been bugging me so far:
                                    The schematic...
                                    03-06-2025, 02:03 PM
                                  • Thetechdude
                                    MSI Ventus RTX 4080 16G Broadview schematic needed
                                    by Thetechdude
                                    Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                    I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                    Thanks.
                                    07-15-2025, 11:15 AM
                                  • ianpoultonknights
                                    Zenbook Flip 15 UX562AI schematic
                                    by ianpoultonknights
                                    Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                    06-26-2025, 02:41 PM
                                  • Adv10119
                                    Need help please! schematic for LA-9982P rev 3.0 (A02)
                                    by Adv10119
                                    Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                                    I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                                    I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                                    01-31-2024, 01:18 AM
                                  • cappercan
                                    Gtx 780 boardview and schematic
                                    by cappercan
                                    Iam looking for a Evga Gtx 780 schematic and board view.
                                    The 780 possidon board view is not close.
                                    Dicky96 has the schematic that would help. I seen a video on YouTube that he was working on gtx 780. If he could post the schematic that would help alot.
                                    Thanks.
                                    01-10-2025, 01:58 PM
