6050A2644501-mb-a02 schematic
  • nassih
    • Oct 2015
    • 280
    • morocco
    hello everyone
    i need schematic for this motherboard hp elitebook 745-g2 6050A2644501-mb-a02.
    the problem is power button and caps lock blinking continuously when i put adapter.
    i have replaced a bad mosfet and cleaning little water damage, the same problem. any ideas
    best regard!
    • 21874
    Re: 6050A2644501-mb-a02 schematic
    No schematic available .
    • nassih
      • Oct 2015
      • 280
      • morocco
      ok tanks for replay
      any idea with this problem
      • nassih
        • Oct 2015
        • 280
        • morocco
        no short to ground B+ is 19v is unstable voltage is between 18 and 19 sensing
          • 21874
          You made a schematic request,so your thread was moved to the schematic requests section. If you want further help start a new thread in the main laptop forum, https://www.badcaps.net/forum/forumdisplay.php?f=23
          • nassih
            • Oct 2015
            • 280
            • morocco
            ok tanks
            • CmMAN
              • Aug 2022
              • 9
              • egypt
              hp 745 g2 schematic please
              i need schematic for hp 745 g2
              motherboard : 6050A2644501-mb-a02
              thank you everyone
              • pooya_pm
                • Jan 2021
                • 259
                • iraq
                Re: hp 745 g2 schematic please
                Not available yet
                • omartancol
                  • Jul 2020
                  • 11
                  • Queretaro
                  hello everyone
                  best regard!
                  This also happends (blinking) wen the battery is completely discharged try to open it and charge it with a 4.3v source (for each cell) or try with a new battery
                  • quic307
                    • Jun 2015
                    • 255
                    • Greece
                    I have the 6050A2644501-MB-A02 and I need schematic.
                    Is it possible to find it?
                    I have problem with the power management u6000, is that BQ24736 ?
                    And the first and second mosfet are P and N? Is that correct?
                    Τhe first mosfet does not turn on.
                    Any help ?
                    Thanks.
                    • quic307
                      • Jun 2015
                      • 255
                      • Greece
                      Any help ?
                      Thanks.
                      Can you help me? I want to know which mosfet and u6000 are correct...​
                        20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                        I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                        At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                        Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                        04-09-2023, 08:04 PM
                      • EffiSon
                        ASUS ZenBook UX3404 Water Damage - Schematic / Boardview / Component detail Needed
                        by EffiSon
                        I have got a water damage Asus Zenbook UX3404 (exact model no. UX3404VC-PURE5) where one of its component got burned, picture attached. MARKING ON COMPONENT is ONLY 5k6 !!
                        Wondering does anyone know what is that component, it is located near the GPU. I have found out the same component near the LVDS cable on and that is how conclude that the suspected burned component
                        Thank...
                        04-20-2024, 03:33 PM
                      • rzsn
                        water damaged G513I
                        by rzsn
                        Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
                        Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
                        12-22-2024, 09:02 PM
                      • TinkerTron
                        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                        by TinkerTron
                        Hey everyone,
                        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                        Instead, here's what's been bugging me so far:
                        The schematic...
                        03-06-2025, 02:03 PM
                      • atunguyd
                        Acer x163w Monitor PSU schematic
                        by atunguyd
                        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                        03-05-2025, 02:08 PM
