Does anyone has the ability to read and program the controller MEC 1633L on lenovo P52? share jtag point pls !!!
JTAG point for MEC1633l on board Lenovo P52
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by Habble7Hello everyone,
I'm trying to repair the power supply board from a Lenovo ThinkVision P40w-20 monitor. The board is labeled with the following markings:
- Main PCB code: ILPI-422 VA (dated 2021/11/24)
The monitor is completely dead, no power LED or backlight. Upon inspection, I found a few components that appear damaged, particularly some resistors that are burned and unreadable.
Attached is a high-resolution photo of the power supply board.
Does anyone have a schematic, boardview, or similar power supply that can help identify the... -
by pc_okayHello friends,
I have this laptop AMD Platform starting & not posting, fan spinning.
When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
CPU and his area heat, maybe the cpu is dead?
...10-21-2024, 10:23 AM - Loading...
