Razer Blade 15 RZ09-02385W92
  • alekk89
    • Nov 2015
    • 32
    I'm looking for schematics for this model
    Board number:
    C1_MB
    MP V4.2
    20180608
  • alekk89
    • Nov 2015
    • 32
    Need schematics of Skylake laptops
    Hi guys,
    I need schematics of any laptop that uses intel's 6th gen or above processors.
    I am looking to find one of them that uses ISL95520 for charging the battery in order to identify a few bad resistors in it's circuit on a razer.
    If you have anything that might help please upload here.
      • 21916
      Re: Need schematics of Skylake laptops
      Just do a few different google (or other search engine) searches :
      Schematic ISL95520 , Compal ISL95520 , Inventec ISL95520 , LCFC ISL95520
      Quanta ISL95520. You sould find a schematic name,then just google that and see if its on one of the free schematic sites or badcaps.You can use the forum search as well.
      • theplop
        Razer blade 2022, 14" PI480 wont boot to OS, freezes
        by theplop
        Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
        I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
        I've run memtest quite a few times, and more often then not...
        03-20-2025, 06:42 PM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • shellybelly
        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
        by shellybelly
        Back Story
        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
        08-27-2023, 10:40 PM
      • Awdev
        Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
        by Awdev
        S/N is BY2011A72401766
        Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
        MB Model is: DA530-MB
        Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
        10-18-2025, 02:13 AM
      • Trodrigue
        razer blade stealth 13 2019
        by Trodrigue
        Hi everyone, I'm posting this message for help. I was given a Razer Blade motherboard because many people around me know that I like to tinker or make things with computer salvage.
        The problem with this board is that the person ripped out the keyboard port from the board.
        But in short, it's not a problem in itself because I'm planning to build a console with this motherboard.
        The problem is turning on the card without the keyboard.
        So I'm looking for another way to turn it on, either by
        using the pins or by using the ITE chip ref: IT8320VG-256 1920-DX0 EA07ZB....
        10-02-2025, 10:17 AM
